Best Reciprocating saw blades
1966chevelle
Indiana
Who makes the best blades? I usually buy Milwaukee blades but a buddy of mine gave me a fire/rescue blade and it was amazing. I can’t find them around me so I was curious what everyone uses and likes?
Kev442
Wi
Was using my MK Morse Fire and Rescues last week and hot metal was hitting my hand. Then it started making little curlies. Never saw that before, I loved it!
1966chevelle
Indiana
Thank you all for the response. I may have to order dome Lennox and Freud Diablo. I am currently rebuilding my dads 55 Chevy that he has owned since 1964 so most of my cuts right now are sheet metal but I normally I use them for .095-.120 round bar stock and stuff like that.
bcradio
New Mexico
Why not use a grinder for that?
A couple of years ago, Home Depot had a sale on Freud Diablo blades. I stocked up on demolition and metal cutting blades. I think I am good for the rest of my life !
laflippin
At this time, at least until I gain more experience with my DeWalt DWE305 with other blades, the DeWalt blades I bought with it are not my favorites.
In an earlier thread on reciprocating saw blades I pointed out a curiosity about DeWalt blades that still bothers me: The shank on the coarse DeWalt blades fits snugly into the blade holder with very little blade wobble. The shank on their fine blades has a narrower isthmus and these blades wobble quite a bit (up-and-down direction, not side-to-side).
Someone suggested Lenox, and I have looked at close-up pictures of Lenox blade collections...the shanks on their blades look uniform across all of the TPI options so I'm going to go with Lenox the next time I need blades for my DeWalt saw.
rmsg0040
Toronto
Just an update, I purchased some diablo blades (swiss made) from our supplier for use at work. Very impressed with them. Cut up 4 ladders with 1 blade, no missing teeth and not even bent. I recommended the Milwaukee's but these are over the top.
Purchased 20 blades and only used one. I was impressed to say the least.
Reese
I don't know who makes the best, but without a doubt the award for the worst goes to Dewalt. They ****.
the intimidator
ontario canada
I'm using the Diablo blades at work I can average 8 catalytic converters or 16-24 cuts per blade threw exaust pipe steel -stainless-cast iron depending on the vehicle Lennox are a close second neck to neck but it boils down to cost Diablo wins unless their is a sale dewalt blades are garbage imho mayby two cats off per blade in good straight cut not double wall stainless haha between the Milwaukee and the diablos you cant go wrong though at least threw the big box stores
seber
Deep East Tx.
I've been using Lenox and Grainger interchangeably but any bimetal blade will outperform standard blades by miles.
ishiboo
Oshkosh, WI
And Freud (and perhaps others) have true carbide-tipped blades now, which outperform the bimetal blades by miles. :rocker:
Fialaja
I’m between Milwaukee and Lennox. When Lowe’s lost the contract to sell Milwaukee, I picked up a ton of reciprocating saw blades on clearance, as well as Makita batteries for my cordless drills!
showags
Twin Cities, MN
I have always had good luck with Milwaukee blades for general use/demolition. When it comes to metal cutting, especially thicker material, the Diablo Carbide tipped blades are in a league of their own. Went through 3 Milwaukee Torch blades barely making a dent in the material, switched to the carbide Diablo and cut was complete in seconds. Very impressed.
tarbellb
Oregon
Carbide teeth will perform better if your cutting anything w potential metal
Lennox has always proved to make a excellent blade across the board
You can find deals on older non carbide but metal rated/demo blades
The other big factor, for me at least is blade length. 9" minamum, prefer 12" for most things
