Best replacement cherry picker cylinder?
MushCreek
Upstate South Carolina
Well, my old cherry picker failed to get it up this morning (I can relate!) I've gone through three cylinders over about 35 years. The first one lasted the longest. Then, I got a two-pack from Northern. One failed quickly; the second one lasted for many years. The question is- Is there a good quality ram you can buy? All of them seem to be similar in price and quality these days (read Chinesium).
I'm gettin' old; if I got one that lasted ten years, I'd probably be too old to use it after that. Or- can I get new seals and rebuild my existing one? I like it because it's double acting, meaning it raises up much faster. Just curious what the collective GJ mind thinks.
mikegt4
sw ohio
Since it has already failed take it apart and see if you can get replacement seals. Any new cylinder is most likely will have been made in China.
66cj225
NH
Are you analyzing the supply chain? A "cherry picker" can be a lot lot of different machines- from picking a jar off off the top shelf to a 110 ft tree worker. The only way a double acting goes twice as fast as a single acting cylinder is by using the return side and at half the power. ?? Do you park next to the surface grinder?
M
MushCreek
In this case, 'cherry picker' is the slang term for a hydraulic engine hoist. The double-acting cylinder goes up twice as fast until it meets resistance.
Lucid Moments
Gainesville, Ga
Do yourself a favor and get an air/hydraulic cylinder while you are at it. I inherited one that already had such a cylinder on it and let me tell you letting a little blow do the work beats the hell out of pumping it a thousand damn times to get it up.
metlmunchr
Another vote for the air over hydraulic. Have one from HF that's still chugging right along at 10+ years. About $90 now IIRC, but with the 20% coupon its $72. It still has the same manual operating capability for those times when you don't want to drag out an air hose.
joe_padavano
Northern VA
^^^THIS! I also went with the HF air-over-hydraulic when I needed a replacement. You can stand to the side and watch for that last wire or tube you didn't disconnect while the hoist slowly lifts the engine.
