best score to date!
Rusty32
Iowa
I usually get some good scores from the company scrapyard, but this one I had to share. 3'x8' lift table 4000lbs capacity. Best part boss said take em there yours free! I got 2 of them
PJNJ
Iowa
Yeah YOU ****! I can see using it for my motorcycles - put a front wheel chock on it and some tie down points and you're all set.
:beer:
DanielC99
Central Arkansas
You ****!
I've been lurking for quite a while and I understand the "You ****" concept, and the first thing I thought of when I saw Rusty32's post is that he, indeed, sucked.
But since I have not posted much I did not want to be presumptuous and bestow a "you ****" if there is a minimum post count or some other requirement that needs to be met before bestowing a "you ****".
So my question is, can just anyone, even a relatively new member, bestow "you *****"?
jakemac
New England
Yes, but it helps if you've established yourself (as you are doing) with the membership so that there are no mis-uses or misunderstandings.
There is only one rule - You cannot **** or imply suckage yourself. :lol_hitti
DanielC99
Central Arkansas
Thanks for the clarification jakemac. As weird as this is to say, I would never **** myself... and I have seen the firestorm that erupts when someone attempts to do that. :lol:
So, ok then, Rusty32 - YOU ****!!! :beer:
