Yesmar
i replaced my henson trays with the harbor freight versions, they take up less real estate in the box. havent had any issues with them.
I have not had good luck with the HF gray rails. I have had too many break. The part of the post that straddles the rail just breaks. The bigger the drive size, the more failures. The 1/4 has not been too bad.I hate to say it, but for the $3 the HF grey plastic rails are just fine, the clips are a bit brittle if you drop them when they are full, but for the money, I won't complain.
Some of mine would not lock at all. There is a limit to the sane amount of force you want to exert. You are trying to force a ball into a space between a socket detent and and an eccentric internal post that it does not fit into. The post assembly is plastic. There is no doubt what will break. I pull the rail out of the box so I want one that locks. If you don't lock them why spend the money, when a simple Hansen post will do? The Gearwrench rails are less expensive and use a simple spring loaded detent ball that is strong enough for my non inpact sockets. When I buy more impacts I will buy more lock a socket rails.
They didn't for a long time, but another member recently posted that they found the Snap-on socket on the site.That's odd, available in Blue Point but not Snap-On proper? I would never have guessed that.
Just found out snap on started making1/4" drive 5/8 deep chrome sockets.
Part# stm20a
Its not listed on the web site but it does come up if you search the part number.
Now my Hanson tray ocd is a little better
I'm a fan of the Lisle socket holders myself. They keep everything organized, are easy to take with and stack nicely. Admittedly I don't think they would work so as well for torx, hex n flex sockets so I keep those on rails. Check them out you may like them.
http://www.lislecorp.com/divisions/products/?product=236&division=1&category=16
These metal, twist lock, and portable trays are very heavy and my favorite,
who sells the old style metal rails ? has to be local. will be holding rarely used stuff.
I had Hansen trays and they took up too much room. I was looking for alternatives when I found these at our local WalMart. So far they have been great and a low cost alternative @ $5.74 each.
Regards,
John
I've been gradually switching from Hanson to Ernst. I can say I definitely prefer the Ernst rails. I've already saved quite a bit of space compared to the Hanson trays. I also don't used the trays the Ernst rails go one. I've been buying separate rails, all in black, directly from Ernst. They're not all that expensive. Plus with them sitting against one another none of them fall over. I have a few more Hanson trays to swap out. Mainly some 3/8" stuff. The Hanson trays with my 1/2" impacts don't bother me too much. Plus some of the larger sockets can just stand on their own. But I highly recommend the Ernst rails for sure. I've been satisfied with all the rails and wrench racks I've purchased.
Need to see the rest of this box
I make my own, can move them around easier for me!
Nice who makes them?
These used to be made by rhengineering .. wish I got more then.
