best step drill
dowmace
KCMO
I have greenlee and irwin. The irwin is about 10 years old and still drills very well.
Ign
Butte Peak ND
I was meaning to start a similar thread! Has anyone used the Milwaukee ones from HD? I used to beat on the HF step bits but something has happened in the past few years and now they just don't hold an edge. But "real" ones are damn expensive, and if just one step goes dull it can be just damn annoying or render almost the entire bit unusable depending upon which step it is, so I'm hesitant to invest "real" money in something.
jakemac
New England
I've had an Irwin that is still good after 15yrs. Lately, I've been using one from a HF 3-pack that has held up well. I don't expect it to last as long as the Irwin, but I've been surprised at how good it's holding up. I expected it to be a one-and-done, but it's still going.
harvey29
Kansas
I've been using my HF ones for a couple years now and the only problem I've had is I broke the tip off of one, but for the price I can't complain.
quattroJoe
FL
I use Irwin and Milwaukee, both are holding up well. Mainly using them on steel sheet metal. The Milwaukee step bits are made in the USA, and priced pretty reasonably.
PT Doc
Has anyone tried the Norseman step bits? They have a slew of them and in sets. Based on the quality of their other drills I would venture a guess to say they would be quite good. And MADE IN THE USA!
Diesel4Life
I own several Norseman bit sets including their 3 pc.UniBit set, they are fantastic quality. I've always been very pleased with their performance.
uart
Australia
Have you sharpened it? :)
Can these things actually be sharpened? If so then how would you go about it?
Do just mean that they no longer have an edge (sharp edge), or do you literally mean that you are somehow managing to sharpen an edge onto them, but they are no longer keeping it?
SuburbanRuss
Redmond, WA
I have an Irwin bit and a set of HF bits. The Irwin cuts nicer, however the HF are surprisingly good. The HF ones are the ones that get loaned out...
A_Pmech
IL
Absolutely! They're very easy to sharpen. Simply grind back the flute until the cutting edge is sharp again. As with any cutting tool, this is best done regularly, before the edge breaks down substantially.
Ign
Butte Peak ND
At least on the ones with the tighter steps I don't see how the average guy would do this with even the slightest semblance of success absent a surface grinder and rotary head of some kind.
I consider these un-sharpenable (sure it's a word LOL) but maybe I'm just ignorant.
edit: I bought the $50 set of Milwaukees last nite which has the two step drills and a few twist bits (don't really understand why) and a case I'll throw away....at least I had a $5 off coupon for email sign-up
uart
Australia
Thanks for the tip Andrew. :thumbup:
For some reason I was thinking that you'd need to grind the conical surface, which would be ridiculously difficult. So just hone the straight flute back a tiny bit to get a new sharp edge, sounds like it should work.
What tool would you use to hone it. Would a small sharpening block (the type commonly used on pocket knives) work ok, or would a small flat diamond coated file work better?
G
greenbikemike
Twin Cities,Minnesota
Thanks for the replies and ideas,not sure I can sharpen it,the lands[steps] are pretty wore out.Thanks again,I'll do some more looking,Irwin looks like they have a reasonable priced one.
Greenbikemike
Angry welder
Alabama
I have and prefer the Greenlee. Everyone I know that uses these for any length of time always refers the Greenly, and its because they have a duel cutting edge and cuts on both sides. I don't know how true it us but I have been told that they are the only ones that has this feature.
uart
Australia
Almost all of the ones I've seen, even the $5 hong kong ones on ebay, have dual flutes. The difference is more likely in the quality of the steel.
A_Pmech
IL
It isn't necessary to re-grind the profile, although it can be done with an air bearing and a cam very quickly on a surface or T&C grinder. For hand sharpening, just grind the flute back into the profile until it's sharp again.
As an aside, they're easy to make. Turn the diameters as you normally would, stopping the spindle at a clocked position (where the flute will go) and withdrawing the tool. The traverse feed rate is equal to the cutting edge relief. This is handy when you need a big step drill. I don't use any relief on diameter.
I just use a narrow wheel on a bench grinder. A cutoff disc in an angle grinder or die grinder also works. No need for fancy stuff here. The finish of the flute isn't all that critical. From the factory they're either milled before heat treat or plunge ground.
