I have a 1,000sq ft insulated shop with hydro floor heat. Last winter I set the thermostat to 45 degrees and it seemed like the water heater ran non stop. I decided to try 50 degrees this year and even on colder days it seems to be running less? Is it possible that it is more efficient at a higher heat? I know we haven't hit sub zero temps yet, but still seems better. Also, it is quite a noticeable difference in comfortability between 45 and 50, and of course it show 5 degrees higher on the T stat. I might spend a half hour in there at night after work, and quite a bit of time on that weekends. But have plenty of toys I like to keep warm. Just curious what you guys run your temps at and what you have found? Thanks!
