Is it any different to the Trident one? I assume they're the same, there are a lot of identical looking ones out there. One difference is some have the rounded part of the slot polished. Mine doesn't.
It's had to put some real force on ratchets turning the pressure screw on really stuck ball-joint tapers, and it doesn't show any signs of wear.
Seems you can pay a lot or a little for what appears to be the same exact tool. I paid a little and i've never had a problem.
In the 30+ plus years that I've owned it I think I've used my pickle for twice. The day I bought it an old guy in the shop I was working at showed me how to pop them apart with a hammer and with those one or two exceptions I've never used any other approach.
The trick is to flex the tapered socket that the ball joint shaft goes into. If you hammer on the thinnest side of the part towards the heaviest you get the most deflection. If you use a large dead blow hammer they usually come apart with one or two hits. If you can't get at it from the correct angle you can usually hold a heavy hammer against one side while you whack the opposite side.
I have three ball joint presses. One OTC, a Mac, and a hub shark kit. I use an impact gun on all three with the Mac seeing the most use (I use these for U joints also). I use them hard, no mercy, if they break....they break. No problems so far with any of them and the Mac is over fifteen years old....
We're talking about ball joint separators, not presses.![]()
Oh. People still use them???
Those destroy the boot and often times ruin the joint themselves. Obviously if you're replacing them, that's not a problem. But I never use forks. Take the nut off and whack the spindle right at the joint. The idea is to distort the shaft hole so as to pop the joint shaft out. Never failed yet....
Uh... did you read any of the thread? The whole discussion is about different kinds of separators, not just pickle forks.
Moose where did you get that one you use?
I've had a few where the threads were rusty and the nut wouldn't come up, it just popped the taper and spun.
I really want to try this
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/ISY8bGof3bQ&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/ISY8bGof3bQ&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>
The answer for when the stud is spinning in the bore is to put a jack under the control arm to use the weight of the car to seat the taper and then thread off the nut.
Looks like a craftsman ratchet? I can't figure how that works?
Is that a wrench in between the hub and suspension link? I'll have to give that a try too sometime!
That video has been around for at least 5 years on a Honda forum. The person wedged in either a 3/8" or 1/2" Craftsman ratchet handle and struck it with a BFH.
The C-type separators....
What's the pros and cons of those? Do they work better than the seesaw types?
Thanks for that explanation, I get itRight you are.
Imagine taking a square and turning it into a parallelogram, you're just making the distance between the hub and the suspension link smaller, but the ratchet keeps the space the same, and forces the joint to pop.
