averagehack
- Joined
- Aug 30, 2011
- Messages
- 9
I have my boat in the shop and am giving it a facelift. I have been sanding on the deck to get it fair and do some major core repair and patching.
I have been looking for the best tool for the job starting with my Bosch Random Orbital and as 36 grit. This tool just does not seem quite up to the job but the dust collection is awesome. (I highly recommend a cyclone on a bucket (Dust Deputy) with a reasonable shop vac.) Then I tried an air powered random orbital from HF that I had around. No so good because you cannot "bear down". Then I borrowed an 8" gear driven (Mud Hog) DA sander and it is great but is not only a "Mud Hog" but an "air hog" as well. My compressor is a 60 gallon/5 hp Ingersoll Rand and it just kinda keeps up. Anything smaller would just not work.
I have been experimenting on the abrasive side as well and have found that the Mirka Abranet HD 40 grit is great. It only come in hook and loop so have only tried it on the Bosch Random Orbital.
It seems like the best combination is going to be an 8" geared DA sander with hook and loop pad and dust collection cover. Then use the Abranet HD. But It would be great if it did not use as much air to run.
So...two questions --
1.) Are there other options that are better for fast material removal?
2.) Does anyone have experience with the different geared DA sanders and know which ones do the job with the least air. The options seem to be:
- National Detroit (The original)
- Ingersall Rand
- Dynabrade
Thanks,
Averagehack
- Ingersall Rand
- Dynabrade
Thanks,
Averagehack
