Best tool for painted/ coated socket head cap screws
afo3
Alexandria, VA
I have about 20 exercise machines (gym strength equipment) that use 3/8 socket head cap screws for the structural elements I need to disassemble and re-assemble. Each machine probably has 8-12 of these that need to come apart.
Problem is the SHCS are black and show scratches easily. What is the best tool or bit set to use for a high volume of cosmetically sensitive SHCS? Appreciate your advice!
RMERR
Northern CA
I think any tool is going to scratch/mar the socket paint. I'm fussy about fastener appearance too. An artist brush and black paint can get down into the socket for touching up, I've done it myself many times or try a sharpie as suggested by Old tool guy.
RMERR
Northern CA
I haven't tried them, but WERA hex-plus bits are supposed to prevent socket deformation. They might be easier on painted socket screws too?
Shiftless
East Bay SFO
Buy a foot of this, cut off an inch or so and epoxy it into a junk socket. You now have a non marring hex driver. And plenty of extra stock to make more.
Or just use a standard driver and touch up scratches.
  • Like
Reactions: Max
That's what I was thinking about, but no chance to search.
reclaimer
Soft jaw wrenches, or Knipex adjustable pliers with the rubber protective caps. Or maybe cover them with a paper towel or cloth and use a larger size socket.
reclaimer
hex heads? sharpie should be fine! I'm gonna have to get that pen Teagueo posted that's even better
reclaimer
I used to work at a hotel where the manager would spray paint the brown leaves on plants green before getting inspected by the hotel regional managers. They would complain about everything.
I suspect the OP with his 20 machines is in a similar position lol. I think with a good fitting hex driver like PB swiss, and some touch up paint, there won't be much to worry about.
pizza
Midwest, USA
run a hex bit in an impact on one fastener and see what happens. maybe you won't even see the wear, and you're overthinking it. if you don't like what happens, it's only one fastener to touch up, and you can move to another approach.
5ubtle
Spartanburg, SC
What client would possibly be concerned with assembly marks on the internal hex of Allen head fasteners on exercise equipment. Sounds like OCD x1,000,00. I think that the factory used no special tool.
Tostal
The Emerald Isle
OP could try using a 'ball-end' type hex key
(idk if there are ball-end socket bits available)
- this should avoid damaging paint at the top surface of the socket head cap screws,
any marking would be midway down the hex hole and might not be visible?
To touch up any chipped paint in the hex hole, I'd suggest using a Q-tip to apply some paint.
Other alternatives might be to fit plastic caps to cover the socket head and any damaged paint
or replace all the removed socket head cap screws with stainless or plated versions (if cost is not a concern).
larry_g
oregon
Leaflessshadetree
Don't ask.
Cut plastic from a plastic bag (the zip lock freezer bags seem to be thicker/tougher than others). Lay it over the screw before inserting the wrench.
