Best trans jack
zkdiesel
chicagoland cornfields
Made sure I didn’t say ****** as some People might get bent out of shape about the gender nuetral shift juice now required
Anyways, what do you guys have and why? My two stage Lower half air gray jack sure smokes my otc one I have as a secondary. Not even in same ballpark as quality
Only have one adaptor head and that’s one that bolts to trans mount. Makes it the best trans jack for fords without square/flat pans. Only downside is when removing or installing new trans onto it and catching bolts can **** by yourself. The jib crane does make short work of that problem but most aren’t that lucky
Most guys never even think they can one hand these compete assemblies in like cake on this setup
whateg01
doo dah, kansas, usa
Dad had an old walker with the four arms and vertical plates that picked the trans up by the flange. I always liked the way that worked so I built an adapter to fit on one of my floor jacks that works the same way. Very stable. The only downside is if I'm working on a vehicle on Jack stands there isn't much room to slide it out. I've wanted to get one of those old walker jacks and convert it to hydraulic.
