Best value for a thermal camera in the $200 range?
GophersGarage
Ontario Canada
I have been looking for a thermal camera for a while.
For automotive use I was thinking something like the Topdon TC004 which is around $200
is there any other options I should consider before ordering one?
thank you
(Note: the Topdon is $207cnd right now and funny to see the green one which is the same unit for $189cnd)
GeoBruin
This guy really nerds out on thermal cameras and he has lots of videos (not just this one)
That said, my GJSS got me the very topdon you posted and I can't imagine needing anything more for general garage purposes.
engineer2
Chicago burbs
I bought an InfiRay P2 Pro Thermal Imager that plugs into my phone. $219 and it works just fine for household insulation checks.
Keep in mind that future generation phones may not have plug in connectors.
signcrafter
I bought this one a few years ago and it has worked good for me around the house and shop. https://www.amazon.com/dp/B09P8BL7CW?tag=atomicindus08-20
While searching for which one I bought on amazon I saw that mileseey makes a couple now. Now experience with it but I did buy their laser distance measurer based on recommendations from here and have been super happy with it.
dscheidt
What's your use case? If you're doing basic shop or house stuff, probably anything will work. If you're doing real engineering or inspection, and need to put images into reports, etc, you need something better.
The cheap stuff might not be as accurate, but the sensitivity is good. If it doesn't matter whether it tells you something is 77 when it's actually 80, they're fine. This is more than good enough for finding building insulation leaks, in floor heating, finding the hot spot on a circuit board, checking if radiators are flowing properly, and other such tasks. The cheap ones also don't save thermographic (the actual temperature of each pixel, not just a color scaled on the hot spot) data, they're just taking a screenshot. again, that's fine if you're trying to make sure you don't drill a hole in your in floor heat.
Stepping up to the fancy stuff gets more reliable accuracy, and the ability to capture images that contain the thermographic data. Some of the more expensive cheap stuff, like many of the topdon cameras, expose the raw data if you hook the camera up to a computer and use their software. (I have no idea if it's possible to use other software with the things.)
My uses are all in the "where's the (hot|cold) spot?" category, so I bought a super cheap one. It's branded 'Mileseey', but there are a bunch of identical looking, and identical spec'd, units on amazon. It was ~$100 at christmas 2024. It's so low end it doesn't have a removable memory card, if you want to get images off, you have to hook it up to a computer. It's also got a usb-c connector, but isn't actually usb-c, so you have to use a usb-a to usb-c cable, not just to charge, but for data. (this annoys the hell of me. It doesn't cost anything to do it right.)
Steel_Rain
I am a major weirdo, and have a FLIR E-54 that is way beyond what I'll ever need. That said, I'd love to have a smaller, lighter and less expensive unit that is easy to deploy. How do you like this?
If we want to go way off topic and next level diagnosis, check out "acoustic" imaging cameras. I have "access" to one of these and they are mind blowing (but also $$$).
