Best way to cut stainless pipe?
tearlessj
Hello there,
I'm having a hell of a time finding a easy way to cut Sch 10 1.5" stainless pipe for a turbo manifold. I currently have a Makita cold cut saw with a new MK Morse blade. It seems to get the tube too hot no matter how slow or fast I go. It also sends hot chips everywhere. It's not pleasant or easy to use. It's also very noisy. Am I doing something wrong?
I'm thinking about trying the Northern tool benchtop band saw. I had a full size bandsaw before the cold cut saw but it took up too much space. Does anyone have any recommendations?
The saw i'm looking at,
https://www.northerntool.com/shop/tools/product_200660083_200660083
Mark_17
I used a big chop saw with that grinder type cut off wheel. It wasn't fun or easy but it got the job done.
If I do it again, I'll invest in a portable band saw
anavrinIV
Bandsaw IME. Early this year I had to cut stainless pipes out of an oven - a sawzall was first choice for accessibility but we did not have good enough blades and it chewed the teeth off half way through one pipe. the port-a-band did the job fantastically when we found it.
Bigblue&Goldie
Hello there,
I have the Femi saw that the Northern is copying and it would be my choice for what you're doing. The Femi blades are an odd length, so you might not be able to find them locally (don't know about the Northern), so definitely order the blades when you get the saw.
ez-duzit
Marina del Rey
I'm having a hell of a time finding a easy way to cut Sch 10 1.5" stainless pipe...
have a Makita cold cut saw...
I'm thinking about trying the Northern tool benchtop band saw...
Both exceedingly poor choices for this job.
Best tool is a (4x6-size or better) horizontal bandsaw.
tarbellb
Oregon
I bet the NT bench top will handle it no problem....
BTW, I have one, it cuts SS all day.
Noworries
Southern California
If all the dia is just 1.5" I would use a grinder with a good quality thin cut off wheel like Camel NOT dewalt or some other rebranded wheel.. the thin wheels reduce friction so less discoloration...
pbon
1.5” Schedule 10 is about 2x as thick as typical 16 gauge SS. I agree a bandsaw is best, but I’d go with a larger horizontal if I had to cut a bunch of Schedule 10. I have cut 16 gauge with my portaband but the blade will sometimes not give as straight a cut as I want when doing angles. Planning on buying a larger 4x6 horizontal.
LXCam
Milwaukee makes bandsaw blades specifically for stainless that I’ve used with great success. But they don’t make the length needed for that saw per the spec. And just my $.03, at the price I’d drop a little more coin and go with Milwaukee long before I’d consider that one.
karoc
Hemphill Tx
Same here using a Porta band,slow rpm cut plus add little cutting oil or just plain ole oil while cutting
mikebaker1129
Huffman,TX
Pipe cutter with a stainless cutting blade.
Swage lok makes a version of a Ridgid cutter for cutting stainless tubing/ pipe.
The cutting wheel for stainless is the game changer.
LXCam
The problem with that is it’ll cause a ridge on the inside of the tubing. And unless you burnish it dead flat and only ream it leaves the **** joint very thin. And since this is all about airflow, you don’t want any ruffles in the equation.
foghorn1966
N. Alberta
The Swagelok stainless tube cutter wheels are a direct fit into the medium sized imperial tube cutter.
