best way to cut vented soffit for light
blackdart66
Trying to figure out how to cut metal vented soffit for some recessed lights.
I should mention the soffit is installed so it would make it a little tough to replace if I screw this up. I know this stuff is thin and I am afraid a hole saw will "catch" and just rip/wrinkel up the piece.
Any suggestions ? would a hole saw work ? sure would be fast and easy.....
Thanks
OccupantRJ
Eastern North Carolina
Make a starter hole, then cut out with aviation snips. You may have to use both right and left cut, depending on how close the hole location is to any wall.
deter
Indiana
if you use a hole saw, run it in reverse the entire time to keep it from snagging
dartsportsteve
NE Iowa
X2
Drill the pilot/center hole, then run the hole saw in reverse. You'll have a tough time cutting it with a tin snips without bending the **** out of the whole panel.
rlitman
Long Island
And you'll probably want offset snips, or maybe even "upright" snips, if you're cutting this "in place".
mayday0017
Houston Texas
x3 running in reverse... I have cut through many of leather pannels in cars installing speakers in my younger years and I could cut through the leather in reverse then put it in forward to cut through the backing. Never caught or tore, could of ran in reverse the whole time but was just slower and well... Time is Money!
BD1
north side
blackdart66
I like the idea of the malco cutter. That soffit material is somewhat "ribbed" can it handle that ? or is it for flat stock only.
OccupantRJ
X2
The trick to doing this is to start near the center, and cut outward in a spiral fashion. Big difference in results, as this provides relief for the waste piece.
