I'm new to the forum so please bear with me:
After you use the acidic solution that comes with most epoxy coating kits, how do you get it off if not by pressure washing, just a garden hose?? Someone wrote in my last post that he didn't like pressure washing because it pushed the moisture into the surface voids and took longer to dry completely. I have a garage floor that is 22 years old, very flat, has one crack, one uncracked expansion joint, and a good deal of old oil and grease spots. I will be applying an epoxy coating in two weeks and am looking to get the floor as ready as I can. Do you have to use the acid/etching solution prior to applying your epoxy??
thanks guys
thanks guys
