Best way to hang/store yard tools?
BigSur
Attached
I’ve seen many clip, slat, hook systems, etc. what do you use and why do you like it?
Currently I have them hanging on nails, but this is the year I’m starting fresh and looking for ideas!
I put together a fancy hanger rack using large screw-in hooks, but I'd need 300 feet of wall space to hang up all my yard/garden tools:
At my sister's house, in her tiny garage, I made a "frog" (along the lines of what a florist would use at the bottom of a floral arrangement) from a round piece of heavy plywood with a "grid" of sorts affixed to the top, placed into the bottom of a 35-gallon steel garbage can. That kept them from all tipping over and kept the tools in one place.
kbs2244
My secret is loops of twine that go around the handle at the working end of the tool
With them in different sizes I can hang stuff at different heights on my peg board
Here you go -
This would be great if I had a long run of wall space:
This is what I made for my sister about 25 years ago. Seems to work okay and keeps the tools in one place:
bargainhuntingking
The Amazing Pacific Northwest
Renegade1LI
long island ny
I usually make custom sizes to fit the space out of plywood.
BigSur
Attached
The twine is a clever trick. I drilled through the end of the handle and made a loop there. Pegboard has been useful for small tool, but my experience with heavier objects been pretty poor.
BigSur
Attached
BigSur
Attached
Here you go -
I always wondered how sturdy those screw in hooks are. Sounds like you have a good experience with them. Thanks for sharing the sketch too.
mattbal
Connecticut
Sorry I don't have a picture to post but I used 2ea sections of green PVC pipe with a 14"-16" Inner Diameter (Not a typo, these are huge ID) that are approximately 14" to 20" long.
I have seen this kind of PVC pipe used for industrial size (aircraft hangar size) buildings storm drains and parking garage storm drains.
I mounted them to a wall and can put all sorts of long handled tools in there. Brooms, pipe clamps, tankers bars, non D-handled shoves, rakes...
for shovels with handles I use something similar to what has been posted abvoe that the handles slide into.
kaymccampbell
Upstate New York
I've got a bungee cord running between a couple studs on the back wall of the shed. It keeps the tools from flopping over on the lawn tractor.
Kenstone1
OK
My shed has stud walls and I had been using HF V-shape Hang-Alls but the screw holes are 6" a part so I had to nail a board across them to catch a stud...not the best.
I thought about cutting them and making 2 single hooks out of the "V".
Once I cut one up I put the 2 hooks close together and tack welded them together to screw to a single stud.
I ended up with a bunch open ends of tubing so I bought a bag of plastic push caps off amazon...cheap.
HF Hang-All:
https://www.harborfreight.com/v-shape-hang-all-68995.html?_br_psugg_q=hooks
End Caps:
https://www.amazon.com/gp/product/B07FM87PMS/?tag=atomicindus08-20
:rocker:
DaDuck
Cottleville, MO
horizontal 2x4 screwed into studs then various hooks screwed into 2x4.
So if you want to change configuration later......not a bunch of holes in OSB or whatever your sheeting is.
Prospecter
Maine
OK
HF Hang-All:
End Caps:
:rocker:
I also like these hooks. Used to be able to get them for 0.99 each with a coupon. Still could use one of those 5 for under $10 % off coupons. I also cut down some of the hooks into singles, and use them that way. When they were too wide, I just squeezed them together. Not as pretty as welded, but sure was quick!:eyecrazy:
Kenstone1
yeh, tack welded, an excuse to use my welder when a couple of hose clamps would work.
And know that I modify EVERYTHING...:eek:
niget2002
Josephine, TX
I just let my kids use them. They leave everything laying all around the yard. Then I don't have to worry about them taking up garage/shop space :)
One day they'll learn how to pick up after themselves. Then I'll have issues with where to put stuff :)
Old school. Drive a 2-1/2" finish nail into the top plate. Drill holes in long handled tools.
Heavy items. Drive a 16d nail in the top plate.
egdede
If I could afford it, I'd keep them in a gardener's truck. Since I can't, I have them in small cut sections of pallet almost like a display rack.
DeeDubz
Socal
Heres my set up. I hate having garden tools in my shop but I hid them in a corner. One of these days ill get a little shed to put all that junk in.
Jackfre
N CA
I have solved this problem, as I own about every garden tool known to man, by dispersing the herd. That way, while never being able to find anything I have reduced the clutter to an acceptable level.
mcdye
I try to keep the min of tools needed and store in a plastic 55 gal drum with the top cut out. I seen others do the same but leave the top and drill holes for the handles to slide in.
BigSur
Attached
In the same boat. I want to keep the garden tools out of the shop; but until then looking to plan for how to keep them as organized and small an area as possible.
y'sguy
Tulsa, Oklahoma
No kidding! If it were up to me I wouldn't have any! Of course that doesn't really work! But I have thinned out my collection and drilled holes in the handles and hang them from mostly screws or lag bolts with the heads removed driven into a 1 x 4 and having it mounted to the wall. A rule at my home is that I demand all these tools to be washed off well before they come back into my precious space. Works about a third of the time! haha.
Thought of building a closet looking affair on the the side of the garage to keep them outdoors,but-really?
And I have to say, They are not really TOOLS!, they are contraptions!
:beer:
CaptPat
Grimesland NC
I like pegboard, it’s plenty flexible just need to spread out the weight a bit. I use it for all the garden tools except the gas weed eater and hedge trimmer
Bigbird
New Hampshire
I keep the majority in my shed in one of these (not my pic). The ones I need seasonally go on a rubbermaid fastrack in my garage. Works great for me.
shedfullatools
Nova Scotia
Don't have a picture of my own setup so took one from google, but I have a 12 foot wall in my storage shed done like this. Works great and quite affordable.
BigSur
Attached
I’m definitely leaning toward clustering/stacking them. Wall space is at a premium. This Rubbermaid is a contender.
mmb617
PA
You and I are on the same page. I've been doing it that way for 40+ years and don't expect to change any time soon.
