Best way to move concrete.
bannerd
Upstate NY
I have about 7 yards of concrete that I need to get inside a basement. I have a walk in basement and I'm trying to think of the best way to fill the basement. The house is on a hill and in a remote area... trucks and pumpers are out of the question. We ended up moving a concrete plant on site, old gilson mixer that will handle a yard with 5 bags of portland. We have water on site.. Currently the thought is to use the 4x4 backhoe bring the bucket up and dump it into a wooded sluth lined with something... PVC?
I'm open to ideas.. we have a excavator as well and though about using that but with the ghosting on the old girl we wont risk it.. the house is near finished. :D
bannerd
Upstate NY
Am I missing something here? How did you get concrete into position for the foundation and slabs (if any) ?
Nah, when the house was built we brought 220 volvos up there carrying bags and slowly dumping concrete into the ICF. We should have done the slab in the basement but covid hit and the client stopped progress. This year they want it done.. we thought about building a troth lined with PVC and it might be the only option.. just looking for suggestions.
larry_g
oregon
We had a project on the farm we could not get the concrete trucks into. We had the truck put it directly into the loader bucket on the backhoe and then used the backhoe to transport the mix to the project. Can you get a small trailer mounted concrete pump into the project. The pump I used on my shop project was towed with a pickup.
lg
no neat sig line
dcg9381
Austin, TX
Photos. I think the "chute" idea is exactly what you need to do...
BombShelter
State of Hockey
They line chutes with HDPE, if you can't get it locally, USPlastics will ship it to you, just use woodworking tools to cut to size.
I'd rent one of these and skip the bucket brigade....
andyvh1959
Green Bay WI
For the chute how about using 10' lengths of 4" or larger PVC drainage pipe? May have to make a "box" at one end to dump the concrete into and direct it into the pipe.
65ranchero
Danville, VT left NJ forever
Sorta what I did for a small pour in a basement.
Took a 12" PVC Sch 40 and cut it length wise in half for a chute and poured the concrete into the top side and used a hoe to help it down the chute.
tarmy
Nor Cal
Pay somebody else to do it…seriously.
My neighbor paid the landscape guy to have about 20 laborers there and they did a wheel borrow and 5 gallon bucket brigade. I thought it was going to be a disaster…but nope…worked great. Moved 12 yards down under a house that was to far to pump to.
PCustoms
VT
Got any pictures?
im not seeing why you couldn't chute this in from a window, mix inside the walk in our rent a pump.
Is this your house out are you the contractor?
LopezBart
Lopez Island, WA
Back in the 1970s I occasionally helped wheel concrete for pool decks in Modesto CA. Perhaps they didn't have a concrete pump or we worked too cheap. The wheel barrows were heavy af; I never dropped one into the pool, but I heard of someone else doing so.
It does work; you do need enough people, preferably young, hardworking and not too smart.
CraigStu
Blacksburg, Va
Assuming you can get water there in a hose I like the MudMixr or even a conventional mixer right outside the door. This way you only need to move the mix and the sand to the site. Not sure what % the weight of the water is in mixed concrete but seems not having to carry it would be a huge advantage.
bannerd
Upstate NY
Got any pictures?
Ended up doing a chute and lined it with plastic. We tried to use a large culvert pipe but it wasn't long enough. The old gilson one yard mixed it faster than we could smooth it! Don't really do photos on job sites :D
bannerd
Upstate NY
Depends on the client ..depends on the contract. In our proposals we have scope of work and once that work is completed the client must come out and initial it's satisfied. If they refuse to come out then in that proposal there is a charge. Many times they want MORE done so we write in an addendum and additional costing. I think using photos for personal things is okay... if the client doesn't want photos I respect that as well.
Kaizen
New England
Glad it worked out. I'll put my experience for others in the future.
First chute i tried I used large sono tubes cut in half and wood to hold them in shape. Had it secured on pump jack platform that I had. Did not work. Dumb idea.
Last one i did i had a piece of metal roofing left over ten feet long. I bent it into a U shape with the paint side on the inside and used 2x screwed through it to keep shape. had it fit through a window and 2 bag mixer at the top side. Did a whole pallet like that. Worked great. I did make sure i hosed it down between pours. Still have it in the corner of the yard.
