Best way to plumb a shop compressor?
blazinspl
Foley, AL
I just bought a Kobalt 80 gallon 175psi and I'm curious as to what the best way is to plumb it into my shop. Is PVC fine or should I use something else? Also, what is the best way to run the PVC so it will trap most of the moisture in the lines? I know you can make a "U" in the lines so the water will accumulate in the bottom and you can drain it out with a drain thing on the bottom.. And is it best to put the water trap before the thing I described or after it?
Any help would be awesome, thanks.
GearHead_1
Utah
Stay away from PVC with compressed air. They can be a very bad combination. L scheduled copper, black iron and some aluminum tubing are types worth thinking about.
Stuart in MN
Minneapolis
PVC is not for air lines; go to the General Garage Discussion section and read the note at the top of the page. There's a good discussion in the How To section about installation of copper air lines.
kartracer55
Yeah, plastic shouldnt be used for air lines. Copper is the best to use simply because of ease of use. Black pipe is a PITA because you need to have it threaded. Get a piece of braided hose with the same ID/threads as your compressor outlet. They sell an adapter to adapt threads to copper lines. Come out of the compressor, and into copper line, make the run up towards the cieling, then go around the perimeter to wherever your drops are. "t" the drops out of the top and loop them back down. This helps to only pick up dry air in the lines. also, T the regulators out of the side of your drops and install a drain at the bottom for water and stuff. The reason for hte flex line is to isolite vibrations from the sweat joints so you dont shake them apart.
If you choose to do this with black pipe instead of copper, you need a filter right before EVERY hose connection because the moisture in the lines rusts the insides of the black pipe and will flake off the coating on galvanized, and it will get into your air tools. With copper you can just install a filter right before each drop.
Slant the lines ever so slightly back towards the compressor so the tank collects the water. You can sweat them with 95/5 tin/antimony solder, it holds up fine, just remember to brace the lines to control vibration.
Jim
jw33
TX
I have basically the same compressor setup. It's a Puma 80 gallon 2 stage. I used 3/4" type L copper pipe and soldiered almost everything except the brass ball valves and the coupler fittings. They are screwed onto 3/4 male adapters. It was pretty easy, but I was a little nervous the first time I charged the lines with 160psi!!! You can soldier the copper with a small propane or map-gas torch. They are like 10 bux for the gas cylinder and the torch tip at Home Depot. All you have to remember is to make sure you prep everything and use flux. I used 3/4, but you can use bigger pipe and it will be like having a larger air tank
....And yes, the pipe before the regulator is bent on purpose so the moisture will drain back to the ball valve so I can blow it out before it gets to the tools...
kartracer55
The pic JW posted looks good, But he def. needs a filter. One thing I noticed though is the short length of pipe. I dont know how much condensation will occur because its not very much pipe.
JW, you may want to look ito the filter/paper filter combo at TPtools.com to take car of the moisture. Its like 120 and it will give you pretty dry air. Well worth it.
Jim
HHStang
Coastal SC
Use copper. I put couplers and shut-off valves in 3 corners of my shop to be able to source the air close to my work. I might also suggest that you locate the compressor outside your shop if possible. I never would have believed it, but the noise they make is horrible. I'm loving having mine outside.
z28toz06
Connecticut
does the fact that the compressor is outside contribute to the moisture problem?
