I know THE best way is media blasting, but short of that, what's the best way? Need to prep some fresh new steel for enamel paint. The metal pieces are 4X4"X12' posts
I've used an industrial degreaser and scotchbrite followed by a palm sander with 60 grit paper. That's not getting it done. No way the paint will stick to this surface. Thinking about some coarse flapper wheels or maybe wire wheels, but I doubt that will be that much better than what I've done so far.
Suggestions?
Thanks.
Suggestions?
Thanks.
......And still make every body happy... Take a nasty rusty steel wheel for example. I charge $15 each. 15 min for set of 4. $60....think how long you could sand and grind and scrape to do 1 wheel and try make it perfect.....Hours and hours, and they still won't be perfect. For $60, I make them perfect, save you 2 days work, customer is crazy happy, and I make $240 bucks an hour to do it. And everybody is happy...
...........Just like any task, the right equipment makes all the difference.
