Best way to shoot angle screws or nails?
weatherby460
Southern WI
I need to install a bunch of 2x4's flush mounted in a pole shed going between the poles. (I think its called toenailing) What is the best way to do this? I am guessing a nail gun would be the fastest, but I have never used one before so I will have to purchase one. If I use screws, I almost will need to predrill holes so the wood doesn't split.
Please advise me what I should be purchasing for a nail gun if that is the best option and also what type of nails.
Thanks
PeterT
Toledo Ohio
One option would be to buy a bunch of these,, if you shop around they are about .50/ea
JBradley500
I was going to make a joke about shooing them in with your .460 (because I want one) but I'm not going to! Good luck in your search.
gdocktor3
Connecticut
Well, do you have a compressor to power the nail gun? Do you do stuff like this often? I bought a Bostitch framing gun from a pawn shop for about $40 a few years ago and used it commercially for a long time. You can go that route, buy new, or rent one from Home Depot. You would be crazy drilling and screwing them. You can probably rent a Paslode nail gun which is battery powered or runs on tiny fuel cells, but they're really expensive to buy and for professionals. Buy whatever you can afford. Dewalt, Ridgid, Bostitch, Porter Cable, Senco, Makita and even Husky make decent nail guns for the DIYer. Generally want to use a 3" long 8d or 10d nail.
Instead of me explaining everything, just read this http://www.framingnailerhub.com/how-to-toenail-with-framing-nailer/
zendriver
Indiana
I have "toe-nailed" 2x4's with screws, successfully, with out pre-drilling.
They just have to be fairly long, so you can start higher up the board.
They were 3" construction screws. Easier to Start them at about 90 degrees, then angle them down and drive the rest of the way in.
Thumper68
Duluth MN
For an inexperienced guy toe nailing with a nail gun you are very likely to have issues. If they are new 2x4's screwing them in with a construction screws should not require pre drilling.
I buy the torx drive in the big bucket from Menards and have no issues with splitting, as long as the wood is new, old wood you are going to split either way.
gdocktor3
Connecticut
To touch on this, square drive screws are the way to go. Its very difficult to strip a square drive.
manwithtools
Lebanon, TN
Pre-drilling is easy and fast if you get in a rhythm. Good excuse to buy a cordless drill / impact combo. Get the torx drive construction screws from the big box store in the 5 lb box and off to the races.
You may need to devise a way to hold the 2x4's flush to the face of the posts while you "toe screw" them in place. It could be as simple as a scrap screwed to the 2x4 to prevent it from pulling inward beyond the face of the posts. This is an issue wither using screws or nails. I prefer the screws because there is more control of the process.
Jim Johnstone
Brantford, Ontario
Robertson, not square drive. Don't disrespect our beloved canadian invention lol. I agree though, toe nailing with construction screws is easy with an impact driver, and doesn't need to be pre drilled.
DekeT
USA
Fast? If you had started at the time of posting you would be done by now.
W
weatherby460
Southern WI
The joist hanger is a good idea...but not gonna work for my application because of how it will be mounted.
I have all the stuff for screwing...but not nailing. I just hope I can get the right angle when I'm screwing.
drink
Confused State
Thanks
Will you post some pictures of the pole shed and how you plan to install the 2 x 4's in it? Knowing the application and purpose of installing the lumber is a must. I am confused about flush mounting them. What exactly do you mean? What grade of lumber are you using and what is it supporting?
Thumper68
Duluth MN
I prefer the torx to the Robertson, with the torx if you get the angle a bit off it still drives well with a Robertson it will cam out and strip the head.
drink
Confused State
Are you trying to enclose the shed with some siding? Do you want to do something similar to what is in the picture or does your shed already have similar framing?
http://www.polebarn.com/static/images/mesre2.jpg
NUTTSGT
Northern Central Ohio
Depending on how many I had to do and high up I'm going, would make the difference between grabbing the framing nailer or impact driver.
W
weatherby460
Southern WI
Here is what I am trying to do. I want it on the inside to maximize interior room. This it to hang an interior metal for walls.
CNGsaves
KS and OK
What is GOAL again ??
Your 2x4's going flat against what you already have ??? Are you adding more insulation ?? Surely you are moving out all the electrical boxes ??
W
weatherby460
Southern WI
I am hanging 3'x12' metal panels vertically. Yes I will need to more the electrical boxes when I install each panel...I just se a 2x4 in place for simulation.
petee_c
KW area, Ontario CANADA
I've found that screwing with an impact driver and Robertson 3" no8 screws was easier to do then with a pneumatic framing hammer. I have a cheaper Campbell hausfeld nailer, and it never got the nails flush when toe nailing.
Sent from my LG-D852 using Tapatalk
logical
Northern fringe of the Motor City Suburbs
Why aren't you nailing through the existing vertical studs into the endgrain of the horizontal nailers you are adding? You can just offset the next one over up or down the width of the board so you always have a clear straight shot at it.
-l_l-l_l-
signcrafter
Ok this really isn't as complicated as some are making it. You don't need pocket holes to do this. Nails or screws will work just fine toe nailed. If it was me I would nail just because it's faster and I have the nail gun already. But screwing is fine if you don't want to buy a nail gun.
Are you putting these ever 24" or so all the way up the posts? If so start on the bottom and install your first board. Then cut two 2x4s that length that you want to space your boards. On one end screw a piece of plywood scrap to each side of the 2x4. Picture a "Y". The plywood will go over the board you ust nailed on and hole your spacer in place. Now set the next board on top of your spacer boards and screw or nail in place. The spacers will prevent the toe nailing(or screwing) from pulling the board and moving it. Then move up until all the supports are toe nailed in. Repeat for all the bays between the posts.
Remember these are just for bracing to attach your metal panels. You don't want them to be an inch off but they also don't have to be perfect. You should see how some of the "pros" put in bracing.
buening
Decatur, IL
Just be sure to zip the screws down far enough so the heads are flush with the 2x4, so that your steel sheeting will sit flush. The Kreg pocket jig is available at Lowes and Menards, but I think they are made for Kreg fasteners (have a large diameter head IIRC). You can predrill the 2x4 on the workbench and even start the screws on the workbench, but if you have a lot just be aware it will take more time. Predrilling will minimize splitting.
Just be aware that toenailing/screwing often times will **** the board in the direction of the angle, so if you want the 2x4 flush with other 2x4s you may want to fully predrill both boards or clamp them in place.
I too prefer the yellow cad plated torx bit construction screws, and would recommend 3" or 4" long screws, depending on the angle you use. Obviously watch out for the electrical nearby ;)
