Best worklight for working under dash
signcrafter
Looking for a new worklight for working under the dash. My worklights are all about 15 years old and are kind of bulky for working under the dash. Any recomendations on a bright compact worklight?
SVIPD
I have this one that I got for Christmas a few years ago and I had to have Sears replace it once and they did with no problems. I love it and gives plenty of light no matter where Im at. Its like $30.00 at Sears
I love that I can set the LED light down anywhere like carpet without having to worry about burning anything like you did with the old school trouble lights.
6531325601p
Jhoff310
Perrysburg Ohio
one of those led headlamps. They are inexpensive and great...the only downfall is if you look away so does your light..
Jeff
ndoran
I have a couple of LED ones that have a magnet and a hook built in them, run off disposable batteries and give wonderful light output they are now easily available and provided you do not need a "brand name" attached can be purchased for $10. they fit into small spaces which is always useful. I will post a picture later.
I bought one of mine in Zellers in the U.S. Target would be similar but you can probably buy them at WalMart
Something like this if you ahve something steel to slap it on:
Something like this for a small pocket flashlight (Less intense):
I just picked up an old "drop light"at a yard sale that uses a 12 V backup light and has the cage and a folding hook. very small, but uses a cord and a lighter plug. Not sure if an auto parts store would still sell something like that, but I can put in smaller bulbs that use the same base for when the BU lamp is too much light.
There used to be an LED light with a magnetic base than had a small globe with lights pointing in many directions also... Haven't seen one in a while though...
Jack Olsen
Los Angeles
I was thinking about this because I'm replacing a turn signal switch later today.
A good headlamp is the way to go, in my opinion. Outside of that, on this type of job I find myself reaching for the LED flashlight with the most diffused light -- hard shadows and bright spots get frustrating. I've got one that's a little like a camping lantern.
bimmerZ5
I love this flashlight for many purposes.. you can hang it on a hook, or sit it down and point the light in all sorts of directions with a very long neck. absolutely the best design i've ever seen. i now own two of them. on a full charge, the LED bulb has lasted me over 18hrs (found out during the major blackout last year in Socal)
bimmerZ5
hey bimmer can u post a link to that flashlight?
yeah, sure:
http://www.amazon.com/dp/B0000222ZP/?tag=atomicindus08-20
The model is DC919 from Dewalt. I got it from a local guy brand new for $15. The LED bulb is from China, found on ebay; about $30. For total of $45 it's an incredible flashlight.
BTW, it takes both NiCd and Li-Ion XRP batteries... but I find it works better with the NiCd because the heavier battery weighs it down better so you can twist the neck out more without it tipping over.
twistedchief
CA
yah under the dash work can **** with out a good light. I worked for a speedo and tech place and trying to hold a light in hand and tools and do the work is a pain and this was back in the day when there was only a big *** hot drop light or a mag light so i had like 5 or so mag light going on. But now you can have it all i now use this.
http://www.striker1.com/tasklights.html
they have all kinds of good stuff there i got most of the line and they work great
signcrafter
Hmmm, I have a dewalt flashlight but never thought to use it. That might work pretty nice. My thought was getting a smaller LED and sticking it up under the dash somewhere so it would light everything up and be out of the way.
DrkMtnDew
I really like those cheap little $3 LED lights that HF sells. good light output and...Cheap :)
Danglerb
SoCal
I have a couple headlights, some HF $3 LED oval things with a hook and magnet, a couple 7w CFL and a 18w Bayco CFL (two double tubes where the others have one slightly smaller double tube). I use some combination of those and a couple different flashlights.
The $8 3x AAA LED headlight is great, but ... can slide off head, a little pesky to replace the batteries, and my head gets tired of having something on it. Still best thing I've found for working in a dark tight spot.
LED flashlight on a tiny tripod or tripod like thing really handy when you need a lot of light on something.
If your old like me, have a pair of safety glasses made with a Rx that gives you a good focus at slightly less than arms length instead of a regular distance Rx.
Lotek
Los Angeles, Ca.
I usually just use my led Stinger, if I need to, I have one of those led headlamps, the only problem I have with hanging lights under the dash is that I forget to remove them.
WVBrady
WV
yeah, sure:
Would any of these bulbs work?
BTW, on mine the flexible hose is too flexible. It won't support the weight of the head when extended. I am thinking of wrapping it in some sort of rubber tape for more support.
bimmerZ5
not sure what you are referring to as "these" ?
my flexible hose is pretty stiff... maybe yours got worn down? or has it been that way always? it's that flexible hose that makes it so awesome... if that didn't hold, then yeah that would ****...
signcrafter
That stinger sure is a nice looking light! Another item for my if I ever win the lottery list.
joedodge
Tampa, fl
The stinger is a great light I have the xenon bulb one and led light. you cant beat them there veryaffordable on the tooltopia web site and in a prfesional setting I havent destroyed them in 6 years. Iver rplaced bulbs and batterys but thats it.
bcradio
New Mexico
yeah, sure:
Did you do the LED bulb mod on this? Doesn't seem too bad. Did you run into any issues doing the mod if you did do it?
signcrafter
You got me all excited with saying "very affordable on tooltopia" but the cheapest one on there is 72 bucks! Maybe someday.
I think I'm going to pick up one of the little LED lights to stick up by the firewall while working and if that doesn't work good I will use my dewalt 18volt. Might have to look into the led conversion for that.
joedodge
Tampa, fl
my bad i was refering to what they go for at cop shops or on the tool truck. i also have a magnetic one with a hook from harbor freight it was $2.99 i leave it in my cart it works great lol and no harm no fowl if i run over it or leave it in a car
zakmartin
Seattle, WA
I'm not a big fan of LED lights when working under the dash since they can change wire colors as your brain perceives it (especially when you're dealing with very thin wires with very thin stripes). I prefer to go with either a halogen flashlight or a good florescent light that is set up to emit a daylight color spectrum (less green than a standard florescent bulb). Also, I find that with LED lights, I get less contrast and they tend to strain my eyes after a while and I end up with a pounding headache.
BBC71Nova
Birmingham, AL
These thins are super handy. I got the blue point version for Christmas last year. Use it a lot more than I thought I would. I later found these Ullman versions on Amazon and they are identical for less money. There is another model too with more LEDs.
abumason
I use the LED light that came in my craftsman nextec kit. I thought it was a little gimmicky at first, but now can't imagine not having it.
Also have a Petzl Tikka headlamp. That thing rocks and the elastic is still good after 8 years of had use.
WVBrady
WV
I seem to have left out the link. :p
http://www.amazon.com/s/?ie=UTF8&ke...vpone=&hvptwo=&hvqmt=b&ref=pd_sl_7jpfj68d9j_b
The hose was always like that. That was one of the criticisms that I read AFTER I purchased mine. Maybe they changed the design.
ndoran
I use these all the time, The red one also has 6 LEDs in the end so you can use it like a flashlight. I paid $9 each for them. they both have a hook and a magnet on the back and fit in small spaces
signcrafter
Where did you get them from?
ndoran
I got them from Zellers and Wal Mart. in the US you might want to check out Target
cglasgow
For working under the dash specifically, I like these:
I got one at Target or some place for not a lot of money. It's great because it won't blind you, it stays cool, and you can thread in and out and around, wherever you want it.
DARKSCOPE001
Pickerington Oh
one more vote for a headlamp. just about every aircraft mechanic has one. so it doesent look dorky in a hangar. not sure about a garage. but man they sure are nice. only bad side is when you gota squeeze your head into a tiny little space and the headlamp doesn't fit. i generally hand myself up a pocket flashlight and turn it on and point it towards the work area. seems to work ok for me. :beer:
