So back to it.
Last Friday was a short day. I was supposed to be leaving to go on a float trip for the weekend. So it was a quick day.
I spent the weekend at a friends house on the river down in the bootheel for the weekend.
By Monday it was back to work.
The day started with rain.
So I finally had the parts so I finally was able to work on the brakes for the 4010.
The new valve part is made different than the old one and it requires a deepwell socket to install. But the new one was too long for a regular deepwell. So I decided to use my spark plug socket.
But then the end was in to far to get a wrench on.
So I had to use a socket on the socket.
But I finally, after all this time, was able to get the full brake valve back together and on and bleed and working.
Dad was trying to get some manure moved but the had an o-ring go out on the lift cylinder of the loader.
But it was a quick fix after grabbing the o-ring kit.
That evening I had Noah take a bunch of boards out of the little shed we picked up a few weeks ago. Then we started removing the nails from the boards.
But while in the process of that we had another shower. About an inch in about 15 minutes.
The day also ended with the water pump going out in my uncle’s truck. Which of corse he just left at the shop for dad and I to take care of.
Tuesday started with checking cattle and an escapee calf.
Got it back in right away and checked the other calves.
Most of the day consisted of picking thing up around shop and getting hay equipment ready to roll. Changed the knives on the cutter, replaced teeth on the rake, greased everything up and had it ready to go.
Dad also cleaned up the 720. We’re going to be using the post hole digger on it and it need a bit of work first so we pulled it in the shop.
The rest of the day was spend taking care of things for the cattle.
Then we moved the hay equipment because plans were to cut stubble clover. 92 acres worth.
