Bicycle Peddle Snapped
Levaughn
NY
A friend gave me a project to do, a bicycle with a snapped off peddle shaft. The broken piece inside the crank arm was flat. I took two nuts that fit just inside the diameter of the crank arm hole. I put one nut on top and one on the bottom and cranked down the press. Once it was tight, I swung the crank arm back and forth loosening it up.
Stuart in MN
Minneapolis
I broke off a pedal on my bike when I was about 12 years old so I took the crank to the local welding/repair shop. The owner of the shop heated up the end of the crank with a torch to expand the threads, grabbed a hammer and punch, and with two or three big whacks knocked the broken stub out and handed it back to me. The whole procedure took about two minutes and amazingly the threads in the crank were fine, no damage at all. I was able to screw in another pedal without a problem.
4xdog
Santa Fe, NM
Not alloy cranks, eh? :p
Just remember, left side pedals have left hand threads !
I saw riding along side of my granddaughter when her left pedal fell off. The threads were slight messed up and who has. Left hand metric tap. Local Nike shop charged me $5 and put LocTite on it.
L
Levaughn
NY
Yes I'll remember. Not knowing what type of metal the crank was I didn't want o heat it up.
Skyman
Central Maryland
A very clever solution. I'd have never thought of trying it. Well done.
Steve
L
Levaughn
NY
I myself removed the crank from the bike to take it home to work on it. It was a 26" Hybrid type bike. I believe the name started with a "J"
L
Levaughn
NY
My friend who buys and sells bikes said the bike is worth about $600, that's why I wanted to fix it for him.
driftpin
I had a couple of 26" Jamis mountain bikes, Suntour components. Sold one to a friend, still have the other, chromoly steel frame, now w/Deore XT on it after I swapped that gruppo out from a Klein Attitude I bought new, spec'ed w/that. Next year, when the XTR gruppo was released, I had that installed, and put the Deore XT onto the Jamis.
The guy who started Jamis was an attorney in FL. He popularized the 'beach cruiser,' but also had high-end (for the times) MTB's like the Dakar.
A good fix on the snapped-off crank. As soon as I saw the crank, I knew it was an Ashtabula-style. Pretty-sure those are forged, not cast. Left-hand threads are distinguished by markings on the crank arm, on a 3-piece crank. It looks like this: III
ipgenie
Idaho
I was riding a bike in Holland about 25 years ago with a colleague and as we pedaled up an overpass on our way to an appointment, my right pedal snapped off. He looked at it and then asked me, "What are you going to do now?", thinking we would probably be missing our appointment.
I just smiled at him, turned my bike around and coasted back down the overpass to a dumpster near the bottom. I'd noticed part of an old bike behind the dumpster as we passed it a few minutes before. When I got to it, I pulled out a wrench from the little tool kit I always carried with me, removed the broken stub from my bike and then replaced it with a good pedal from the broken junk bike. Fortunately it broke off right at the pedal so I could easily remove it with a wrench.
As I was putting my tools away, I looked up to see him staring at me with his jaw hanging open. I smiled again and then I started back up the overpass. He hadn't known me long and the idea of carrying tools or making my own repairs was completely incomprehensible to him.
Squankum
Southeast
Bicycle repairman? But how?
