Okay in the next several months i will be moving back to indiana (currently active duty in the Marines) and buying a good little swath of land. I want to find something between 100-150 acres. I will be building a house on it as well as a nice work shop and studio for my photography business.
My plans so far are 50x100 (16-18 tall) structure. It will house some basic machining equipment (think cnc lathe and cnc 5 axis mill) as well as the more common things like drill press and all the pneumatic tools.
I am very much in the planning phase right now but have been thinking something along the lines of about 50x60 being my shop area with a dividing wall in the center with the other 50x40 being my studio area.
I've been doing research on here and talking to a representative from anthem steel about this project and i'm trying to narrow down on more of what i want from the building itself, foundation, electrical needs, and plumbing needs. So i'l start off here with what i have gathered so far then you can all laugh at me and tell me whats right and wrong
BUILDING:
50x100 with steel siding with a divider at the 60ft mark with sound deadening properties to seperate the shop and studio. I will also have several "offices" inside as well as facilities.
FOUNDATION:
I really have nothing here. I'm much more of a motor and mechanical guy. What should i ask for or demand for the area in southern indiana (i realize a surveyor and ground survey will yield more accurate results).
ELECTRICAL:
I will need 3 phase 440v most likely but not real sure what goes into it other than it is easier to get when i build it than put in later. Any special considerations on this end? Most of the photography stuff doesnt use much power and isnt super high load stuff.
PLUMBING:
I want a full facilities out there. Nothing less than a bathroom on each side with a shower on both sides. I assume that is more straight forward but anything special i should take into consideration or ask/demand for?
If anyone has any helpful comments, concerns, or especially advice i'm all ears. I'll post up my initial terrible sketches of alittle what i'm thinking of when i get some time.
BUILDING:
FOUNDATION:
ELECTRICAL:
PLUMBING:
