big Gearwrenches
carterbeauford
NW PA
I have a few massive Proto wrenches but I'd like to build a matching set. I see Gearwrench makes them up to 2 inches and 50MM in metric. delighted to see they make a 2 inch wrench to take the axle nuts off my 1941 John Deere. any own them? I assume they'll stand up to the abuse of working on farm equipment.
26 inches long :lol:
Wakefield
Arlington VA (but would like to get out to country
Compared to a big Wright?
the Wright 1-1/2" is much more gnarly looking than that picture.
I doubt if any ratcheting wrench made can stand up to abuse of breaking loose rusted bolts as well as a (plain box end) big Wright or Williams.
rob0781
Canada
If you break the nut/bolt loose first and used the ratcheting end were a socket won't fit I'm sure it would last.
Hammer1963
Kentucky
I have been using the larger Gearwrench wrenches (36mm - 50mm) for close to 10 years now and they have held up with only one breakage. It was quickly warranted through my Matco dealer with no problem. Should work in your situation for speeding off those fasteners.
Danglerb
SoCal
I bought my larger GW from Cripes, not too crazy of prices, but as I recall not all sizes, but I stopped at 36mm assuming I could do some back and forth SAE/Metric on some.
The ratchet is fair a amount larger diameter than a box end, so clearance could be an issue, great if its not.
Other option if they make them are one of the ratcheting open end design, aka speed wrenches and other names.
Mohawk Dave
SoCal
Dang, I need to go back and reflect about the 8 million fasteners I've broken loose with my GearWrenches.
I've always been weary about using GW to break stuff loose, and therefore usually do not. Assuming you(not you in particular) aren't being a dipsh1t and trying to break "absurdly rusted tight, should have a torch ready" nuts/bolts, I'm assuming from you're statement I should go ahead and put a little more trust in them...is this correct?
Have you had them bust on you when you thought they shouldn't? Do you ever grab a box end? Will you leverage another wrench on a GW?
Even though mine would be warrantied, I do not abuse tools. I just do not know what "abuse" is considered yet for a GW.
Thanks. :beer:
Hootbro
Delaware
Thanks. :beer:
From a technical standpoint, the GearWrench ratchet end is not going to be as strong as a normal box end wrench.
From a practical standpoint, the GearWrench should be fine most times and when not, you are really in the territory where a socket and breaker bar should be used anyway.
