Big Maxx Draft Hood Connector Question
sparky2436
IN
Hello everyone - I am a brand new member looking for advice in helping my son install a Big Maxx 50K BTU natural gas unit.
My main question appears to be a common question running through a lot of these posts - making the connection to the furnace flue outlet. I have gone through most of them - but I am not finding the exact response I am looking for.
The furnace flue outlet is just shy of 4" OD with three (3) pre-drilled holes spaced approximately 120 degrees apart.
We are planning to run 4" vertical B-Vent. We purchased a 4" draft hood connector which fits over the factory installed flue connection. I assume we want the draft hood connection to fit OVER the factory flue connection - is this correct?
I also assume we would need to try to match up the hole locations or drill three (3) new holes through both the factory flue connection and the draft hood connection?
I was planning to install 3 - #8 self-tapping stainless screws for this connection to the heater.
Is any hi-temp sealant required or recommended on these screws?
Any advice and recommendations on your experiences that you could provide would be greatly appreciated. See attached photos. Thank you.
cschuler
North Dakota
I have the same question! Any chance that you could let me know what solution you found? I would love to see some photos of how everything it mounted and vented.
fitter30
Peace Valley,mo
Don't know how snug your take off is to the factory but if it is nothing is needed. A little loose they make a hi temp silicon red hi temp caulk. Those screw holes if they can be a line fine but as long as three screws are there that's all that's necessary. Just look at b vent it's not water tight.
