Big Maxx Garage heater problem
LEVKO
minnesota
i have a 75 k Natural gas big maxx. the vent fan starts,the electronic ignitor starts.(the spark is minuscule ) the gas turns on, it doesnt light ,the unit then shuts off. How big of a spark does it need to ignite. could it be the ignitor or the unit the ignitor is plugged into.
BillK
Beautiful Southern Maryland
I would not think it would need much of a spark to light the gas. Are you sure that the gas valve is working properly and actually allowing gas through ?
CNGsaves
KS and OK
Could be getting some "wet" gas in wintertime . . . ie more moisture. Do you have a drip leg on NG supply line to heater??
+1 to double check you have good NG flow that is dry gas. Good luck.
L
LEVKO
minnesota
when ignitor turns on i used a long reach fire starter and sparked it. the gas ignited . it went thru a full heat cycle then shut off. When it was time to re start the same happened and had to manually re ignite the gas. This unit worked fine for a while, then this problem
Basstracker34
I'd call big maxx customer support. They've got a great reputation for customer service.
Take a picture of your install. Might help us diagnose an issue.
chickenhauler
Pennsylvania
I hate to jump the gun, but it's most likely your circuit board. After 3 years of flawless operation, mine went 2 weeks ago. Mine was visibly scorched behind the ignitor. Customer service shipped out a free replacement right away.
dfiler2
NW Minnesota
The position of the igniter can be fussy, check the manual and see what it says, It sounds to me like an igniter problem is most likely the issue.
CNGsaves
KS and OK
+1 to call to get diagnosis help from Big Maxx. Hope you don't have control board problem.
L
LEVKO
minnesota
Thanks guys i pulled out the ignitor, repositioned the electrodes for the hundreth time and solved the problem, i think
thanks again
L
LEVKO
minnesota
Finally got hold of Mr Heater, they sent me out a new control board and now the unit works fine again. Guess what I was still under warranty, didnt even have to pay for shipping.
Kamn
Ontario, Canada
I just had the pressure switch on my Big Maxx heater **** the bed the other day........only a year and a half old
replaced it and all is well again
