I am hooking up my unit in Ontario and there is a door about two feet below where I want to put the exhaust exit. Is there a code issue with having the chimney over the door?
I rarely use the door if that matters.
My only other choice would be to go into the attic up a few feet and then through at the same point. I guess that I could also veer off at an angle to get it away from the door if it is still against code...but I really don't see it being an issue for a heater that will be used on occasion, but....
thanks
thanks
