londonsteve
Has anyone changed the wheels on a floor jack to larger and maybe pneumatic ones, I often use a floor jack outside on a gravel drive and would like a jack with higher ground clearance and easier to roll. Any ideas?.
pneumatic tires will easily hold the load he is talking about
Get one of these.
It has pneumatic tires.
(took me a long time with Paint)
I read about a guy putting bigger wheels on his floor jack in one of the 4x4 mags years ago. It did hurt the rating of the jack, but I never pickup 3 ton on my floor jack. Normally it's half of a 4,000 lb vehicle. So that would be around 2,000 lb. 4 wheels with a 500 lb capacity and you are there. If I remember the article correctly the jack no longer had swivel wheels in the back. It had 4 wheels on straight axles. Pneumatic tires would be interesting if one blew, but large solid tires wouldn't bother me. As we all know jacking on crazy angles and soft ground can easily lead to a tipped over jack and vehicle or worse.
later
Jeremy
Can you figure out how to center a couple of big wheels near the center of gravity of the jack. Mount them on a spring loaded axle that will carry the jack but retract when loaded? Or have the big wheels on a toggle that will retract them for lifting.
lg
no neat sig line
