I don't get it...was it because it was just convenient at the time...was your tool box too far away at the time and you had these exact 3 piece tool on hand when you somehow came across an unexpected crank pulley you needed to remove?
I always worked on a hoist with my toolbox a few feet away. So I am curious. I only need to reach for two pieces, the socket and a longer lever (a twelve point and a breaker bar...a 3/4 inch if space is available), I would save time by not opening the hammer draw. I would save wear and tear from impacting the teeth of the ratchet... remember, applying steady torque is what the teeth of a ratchet are designed for... impacting the teeth will significantly prematurely wear out your ratchet.
I save on fatigue so I can continue doing crank bolts all day long if necessary. And I only put two pieces back when all is said and done.
I guess you may have been laying underneath the vehicle and no clearance for a longer lever...or perhaps you had no way of jamming the rotation of the engine (another reason I use a long lever because my other hand is holding another long lever of sorts jamming the flywheel)...I can see that happening perhaps...still, hammering a 3/8 ratchet, why? A T-bar sure, a breaker bar if necessary...unless you only had a six point socket and couldn't get the angle you needed...I think maybe you just needed a twelve point socket...leave the six points for impact sockets. I mean no one ever thought a six point spanner was more useful than a 12 point spanner in general.
I need an explanation here.
