birds
Gary S
Bismarck, ND
Just live with their mess until you can close up the building. They can't bother you once they can't get inside.
Work double time finishing up the building.
volvo
PNW 45th Parallel
Loud gun fire, shotgun, fire crackers?, Run down to big box store and get a super large tarp for the openings.
House Sparrow
Lewistown, PA
Hang a few fake owls over the entrances, leaving them suspended so they move some. These blackbirds are probably starlings, which are actually pretty smart birds, and will quickly figure out that a non-moving owl decoy is fake. Moving ones should scare them enough that they won't come close enough to find out.
They do make starling traps, but the traps fill up quickly and won't do much good if you have a large population of the pesky birds, which most areas do. I like birds, but I could do without starlings. There are just too many of them, and they get into everything they're not supposed to.
BADSIX
oregon coast
why don't you see if you can pick up some netting and cover the door area. other than that i think you'll just have to wait untill you get it sealed. the owl thing doesn't work very well, the birds are smarter than you think.
lotsoftools
Inland Empire
I had good luck with rubber snakes. I put a couple of them under the carport where the birds were trying to make a nest and they never came back.
64dragnwagon
Northeastern Tennessee
If you have no concrete for them to $#@! on then what are they hurting? I had the same problem, they built 2 nests in my new building and crapped on the ground then the concrete. When I put the doors on I knocked down the nest and cleaned the bird ****, no problem. I think if this is the biggest problem you have on your build then you are one lucky man.
D
Dave Maxwell
Kickapoo illinois
Just worried about them making a home. At the mercy of the concrete guy now. I saw one in the soffit area today. I have 16 foot sides. So getting up to the top is a problem
64dragnwagon
The nest in mine were inside in the trusses about 15' high. A 16' 2x4 and they were gone. Or a ladder but the 2x4 was handier than getting the ladder out. ;)
wdlfbio
pellet gun a few of them and those that live will quicklhy get the idea. The concept is to teach them this is not a safe place. They are smart birds and can tell the difference between life threatening and lame. Static deterrents, as mentioned above, fail. The order in which it is hardest to harass birds is 1) feeding, 2) breeding (***), 3) loafing about. Your situation is #2 and not too tough to alter that behavior. But, if you give in now, they will be back bext year and peck out the hardware cloth used to protect your eave vents.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Watch them and destroy any nests before they complete them. A garden hose works well. They will probably get the idea and go somewhere else. Smoke them out if they won't take the hint. Once the shell is sealed you shouldn't have any more problems but you might get an occasional bird inside. Pellet guns can also perforate the metal. Back when I was a kid the police used a BB gun inside buildings.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Kill one or two of the birds and hang the dead bird(s) by a string in the doorway. They will get the clue. An older guy used to have Bluebird houses up but the Sparrows would always take over and toss out the eggs, or set in the box hole when it was hot and suffocate the baby Bluebirds. He started trapping the Sparrows by going up behind the box and covering it. He would then twist the head off of the Sparrows and drop them to the ground by the nesting box. He would let the other Sparrows see him do this. Within a couple of weeks the Bluebirds took over and the Sparrows were gone.
badbascom
Hang plastic walmart type bags so the wind can rustle them, I like the pie pans though also.
barks
Borrow the neighbor's cat. Keep your dog, however, to chase the cat away when the birds are gone.
D
Dave Maxwell
Kickapoo illinois
Going to lite a fire while the floor is still dirt. Then after doors and stuff are done I will lite some firecrackers inside to scare them away then close door. Pigeons at work don't mind smoke or noise. They fly all over there and **** on top if our tool boxes
ed_v
Kentucky
I have a bad bird problem as well. When I go in and start working they all leave.
Ed
larry_g
oregon
We used to use a 22 with bird shot in it. Would get the bird but not harm the metal building.
lg
no neat sig line
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Big birds. Wow
Just like playfull children as they are all Parrot species and they say at Adult age they have a brain equivalent of a 5 year old. Cockatoos can talk well if trained. A neighbour had one years ago that always used to call out 'MUM' every time the back screen door shut with a bang.
Even seen Cockatoos here drop Pine Cones as bombs that way they can access the seeds inside after they hit the ground.
D
Dave Maxwell
Kickapoo illinois
Company I work for had an opening for a traveling tech. I almost took it. Australia would have been one of the stops. We sell dump trucks to mines and the mines sometimes have us come over to give technical assistance
