Bit driver handle ?
afm
Emeryville, CA
The nicest you can get at Home Depot is likely the Klein 32510. It's a great bit holder, but in retail stores you can only get it bundled with a bit set. It's ~$30 and comes with 32 high-quality bits.
Obviously, that's a downside if you don't need the bits, but the bit set comes in a cool holder that stows on the blade.
D
dubdoc
Milford Station, N.S.
Hmmm, yeah, Home Depot and Princess Auto had some holders, but were all ratcheting big hunky fnortons. Not for me at all. Does Snap On have anything?
bonneyman
Desert SW
I had a pair of Snap-On clones but sold them.
The out of production Craftsman tri-lobe is really sweet - perhaps you can find a NOS somewhere. I got mine out of the classifieds here.
Bighead38
Rockland County NY
I’m sure they do. I think I have a blue point one. Funny I have a bunch in my box and usually grab a cheap kobalt one because the cap spins which is really nice imo.
neophyte
Pennsylvannia
Most screwdriver and tool companies make bit holding driver handles.
The main thing is to consider what type of design and features you want.
Magnetic, non-magnetic, simple retention ring, or a locking sleeve for instance.
Locking sleeves make the bit holder wider, but can prevent the bit from getting pulled out in an awkward place if the bit gets stuck in a tight or rusty screw head.
Magnetic holders can help with holding steel screws on a bit, but the magnets will also cause rust and metal filling to get stuck to the bit head.
Simple retaining rings don’t always hold the bits as securely as a magnet or retaining ring, but also don’t have the problem of being nagnetic, or the width of the locking sleeve.
Then there’s the shank.
Some bit drivers have a smooth round shank.
On other drivers the shank might be hexagonal or knurled, allowing you to easily turn the bit driver shank with your fingers, which can sometimes be useful.
Then there’s the handle material.
Options are molded or turned Acetate type material, like was used on Craftsman, and Armstrong, and most of the Pratt-Read made screwdrivers for decades.
The Acetate in impact resistant, relatively durable, but can become stinky over time.
The turning profiles can vary but in many cases are similar.
Cast Acetate handles are another option.
The ergonomics can be better, although I’m not sure whether the material is as durable as the turned handles.
Then there are modern molded plastic handles.
Some are just the plastic.
Others are plastic with inset rubber material, which can vary in formulation.
These come in everything from weird German “ergonomic” designs like the Wera, and Felo driver handles, to more traditional squarish shapes like the classic Snap-On/Williams handles.
One thing to consider with grips that are dual molded with rubber inserts is that the rubber inserts tend to make the driver handles less durable, since the rubber tends to start peeling out over time with some drivers.
There are also companies like PB Swiss, that use a Santoprene material that is grippy like rubber, but which may be more durable in some uses.
There are also manufacturers like Wiha and Witte, who make hard handle drivers with special surface textures so that the driver handle is still grippy when oily. The Wiha drivers are branded “Microfinish” I forget what the Witte drivers are called.
Also.
Some bit drivers store bits in the handle, and others don’t.
The number of bits stored can also vary from a few, to a dozen or more.
There are also bit drivers like the Wiha Driv-Loc where the handle accepts longer replaceable bits that are dimpled, and can be locked at various lengths.
These are sold as handles for the long bits(which are 6mm not 1/4”) but there are bit holders available for the handles.
Indexmill
Central NC
ChevyEFI
Phoenix, AZ
Toptul FTBB0824. Magnetic, and locks regular 1/4" bits in. The handle lets you get stout torque into the job. No storage. The handle is rubberized a bit, but solid.
d.mcfarland
Western PA
Depends on if you want cushion grip or hard handle.
If you want hard handle, get one with another way to add torque, such as a shank with the appropriate place to put a wrench.
liliysdad
Brownells Magna-Tip holder. Best i have used, and I have a couple different lengths. I prefer the Law Enforcement handle.
Noworries
Southern California
LOL jesus christ for the price of that stupid snap on i can get 72 cans of coors light AND 2 of the dewalt handles... decisions decisions...
And you know there are guys that will actually buy that snapon handle
Wamsutta
Amarillo, Texas
Evercraft at NAPA.
Rubberized grip. Comfortable.
NWMDC
bonneyman
Desert SW
The one I used for doing HVAC for years is a Craftsman vinyl handled sourced from Fiskars. The soft nibs bend and fold under pressure to give you superior torque and no hand strain. They do eventually break off but while they last they're great!
I believe they are NLA but I've managed to find good condition examples at estate sales and thrift stores.
HenryAZ
MEMBER EMERITUS
South Congress AZ
For slim (hard to reach places), I like Felo or Wiha handles. Otherwise, Wera Rapidaptor, either permanently attached to the handle or the extensions (50mm, 75mm, and 100mm).
measuredtwice
USA
Menards has the Felo Ergonic for $13.50 shipped free. That's after a 11% rebate. I haven't done comparison shopping so check around to see if that's the best price. If not, it's probably close. https://www.menards.com/main/tools-...wdriver/0715753711/p-1475244648012-c-9158.htm
Suncoast has a Bondhus set that includes a bit driver as well as fixed screwdrivers for less than $15. https://www.suncoasttools.com/crm/ItemPage.aspx?ItemNumber=BOSCREWSET+16758++BO&VendorNumber=BONDHUS
If you like the old timey ones with the hollow handle for bit storage (MADE IN USA), then there's an Ebay auction with lots of new old stock for less than $5 shipped. Wouldn't shipping and fees eat up most of the $5?? :dunno: Seller is probably only getting pennies from that sale. The same drivers have been branded by many brands. They were common in the 1990s... some still sell them today.
Climatecreator
CT
That Malco is very nice and $10.00 on Amazon; an awesome every-day user. I do wish they made its "baby" brother; a 1/4" bit holder with a little shorter and a little smaller diameter handle for use on small fasteners. Think small Torx for knives and the like.
I have the Malco https://amzn.to/3k4fS2N and I love it because of the locking bit mechanism. For the short one I use this. https://amzn.to/3i4EsyN
CC
Al Borland
72 Coors Lights...
How many Yuenglings?
Steve_P
I have the Wiha with the standard soft finish grip. No issues
seber
Deep East Tx.
I have a fair number. They all work about the same. I grab whichever is close. When Wiha finally offers one with their sliding lock sleeve I'll buy a dozen of them.
measuredtwice
USA
I'm not sure which lock you are looking for. Wiha has made several. Some seem to be more common in Europe and some are discontinued.
The Ultra Driver has a lock
https://www.amazon.com/dp/B01J92O2NA/?tag=atomicindus08-20
Here's the Clikfix on the UK Amazon
https://www.amazon.com/dp/B001JGBN1O/?tag=atomicindus08-20
I think the one below is discontinued but you sometimes find it on Ebay as new old stock
http://carbideprocessors.com/7pc-clicfix-bit-holder-slotted-phillips-wiha-38033/
I think this one might be discontinued also. It has bit storage in the handle.
https://www.cromwell.co.uk/shop/han...36933-clic-fix-magazine-bit-set/p/WIH5733693C
This one takes power bits instead of insert bits. It is also sold rebranded by Festool.
https://www.amazon.com/dp/B01B8L4M7G/?tag=atomicindus08-20
