Greetings.
I'm looking for a set of drill bits for drilling out tough bolts, such as hardened exhaust studs. (Even with my favorite dewalt HSS drill bits I often have a really bad time getting anywhere.)
I've read a few sparse comments about solid carbide bits being great but I never used them, and I can't find sets of them anyway. Are they worth the price (like $25-40 a bit)?
Yes the solid carbide bits are worth every penny. They will drill just about anything.
RHC - Rockwell Hardness C
HSS Drill Bits - Work well up to the 50ish RHC
Drill - Mild steel, Some tool steel, Some Spring Steel
No Drill - Hard Plate, Anti Drill Plate, 404c Stainless Steel
Pro - Good in Hand Drills and most drilling applications
Con - Has limitations in hardened steels
Cobalt - Works up to 58ish RHC
Drill - Mild Steel, Some Spring Steel, Some Tool Steel
No Drill - Hard Plate, Anti Drill Plate, 440C Stainless Steel
Pro - Good for hand drills and most drilling applications
Con - Has limits with hardened steel
Carbide Tipped - Will drill almost any steel, Hard, Stainless or Mild.
Pro - Drills all steel
Con- Blunt tip requires extreme pressure to produce cuttings. Drill bit is hard to start on all steels.
Diamond Coated Drill Bit - Cuts on most steels(Not Hard Plate) just not for long.
Pro - Will Drill most steels (Not Hard Plate)
Con - Cutting stops quickly after diamond grit has warn off, Then behaves like HSS bit
Solid Carbide Drill Bit - Cuts all steels.
Pro - Sharpened points wont "walk" like carbide tipped bit. Cuts all steel
Con - Sharp tip and fine edges can chip easily and ruin drill bit. Not for hand drills. Expensive!
For more information enter “The Ultimate Guide To Drill Bits” ____ Tube video into your favorite search engine and watch the video.
