Black Friday & First Plasma Cutter Options?
TimberMan
Ok folks, I am not sure that I "need" a plasma cutter but since it is black friday, today may be the day to get one just in case. I plan to make some chimeneas / fire pits / fire rings from old propane tanks and other scrap I can get my hands on and at some point I may need it for repairs on my tractor.
Given my uses, I doubt I need a cnc compatible plasma cutter but I have no idea what is junk and what is a good deal since I am just getting into metal work. Any advice on where to start or what to stay away from will be appreciated.
Thanks!
NUTTSGT
Northern Central Ohio
I bought a Forney from TSC as my first one. STOP. Don't even look at them.
From that point, I went with Hobart as I was on my second Hobart welder and had good luck with them. So I went to Cyberweld.com and bought a 27i plasma cutter. I had one issue and it went to a repair shop under warranty for a o-ring/diaphragm issue.
So guys have had luck with some cheaper import units but my concern was parts/service.
What I will suggest is getting one that can cut bigger then what you might think you need. . . . 1/4" steel ? step up to one that will cut 3/8"
zendriver
Indiana
I was ready to go for the Arccaptain multi process, then remember "wait, I already have a nice welder and plasma cutter, that I am too busy to use"
Although I like a pilot arc, Would consider ordering this.
MT800
Montana
What is this pilot arc you talk about. Plasma is in the back of mind. Not to the point of finding out what I think I need.
