I dont think anyone has mentioned the pipe is a decent qualitySTEEL and the fittings are MALLEABLE IRON .
The pipe I'm not super worried about but what PSI can you run the fittings at?!
I'm building a liquid propane flame projector for a pyro music firework show. They want a 100ft+ height flame for at least 11 seconds, pretty tricky. They tried a bunch of commercial flame projectors but none of them could go that big.
I found a 33LB forklift propane tank dirt cheap. The stock liquid propane output valve has SUPER slow flow. So instead of using the stock valve I took out the pressure relief valve and put a tee where it screwed into the tank (3/4" NPT), screwed the pressure relief into the tee and put a 500psi rated stainless steel full port ball valve on the other tee port. All the flow you could ever want (run the tank upside down for liquid, right side up for vapor).
The scary part is liquid hammer
There's a digitally controlled solenoid flow valve (on/off only, and it's pretty much instant) and with the ball valve fully open (running at full anger) I'd imagine there's going to be big liquid hammer when it closes!
They make a soft close solenoid valve but I wouldn't be able to use ONLY that valve as the flames dance to music for a bit before the big flame and need instant on/off for little fireball puffs. I think I could install BOTH valves (in series even) so during the music I can use my existing quick open/close valve, then during the full anger run I can lock the quick valve open and use the slow close valve to send up the big flame.
Another issue is the fittings get really cold when I run it at full anger. Does temperature effect how much pressure the fittings can take? I'm talking super cold like as in -44c/-47f. After the ice fell off the fittings the first time I used it they rusted almost instantly.
Where can you get beefier fittings? I found a shop selling stainless steel fittings and pipe but they said they are only rated to 150psi!?? They could special order me some 200psi rated ones but they wanted crazy cash for them.
The first time I ran it at full anger the ball valve cracked where the input threads are (on the high pressure/tank side). Luckily it wasn't a large leak and I was able to turn off the pilot light before it ignited. I had to vent all the gas out of the tank to replace the ball valve. I believe it cracked due to the huge amount of thrust from the liquid leaving the solenoid flow valve. It put angled pressure on the pipe and the ball valve is closest to where a pivot point would be so experienced a ton of bending force. I'll have to make sure I super support the solenoid flow valve and piping so no physical pressure is applied to the pipe/fittings.
Let me know where I can get beefier fittings if anywhere. Brass or stainless would be nice (to stop them from rusting instantly). Would like to avoid galvanized so no flakes make it into my control valves.
Get your own numbers. Vacant lot. Sand bags. Vertical opening short pipe blast shield. Co2 tank for 700 to 1000 psi. Hydraulic lines. (Just kidding. Destructive testing isnt for amateurs)
If my regulator ever fails we'll find out real quick! Nitrogen (3000psi) fed directly into the propane tank at 175psi (3/4" port from the nitrogen tank, 3/4" in/out port on the regulator, 3/4" jackhammer hose, 3/4" inch port directly into the forklift propane tank). Common practice in hot air ballooning (nitrogen injection).
And yeah yeah, I know, it violates the cert of the tank and probably a ton of other rules too.
LETS COOK!
-Jamie M.
