Above 1200 Sq/FT Blackbyrds Basement
Blackbyrd
TN
Thanks guys!
I agree now I gotta figure out what to do about the front.
Im a sucker for the ss bumper but that means paint work. They make the work truck satin black bumpers and ive found those a few times.
Relly wish I could take the side molding off, but the precious paint job is gonna make that impossible unless I want to repaint the whole truck.
It really needs a good detail, but im hesitant to hit it with a buffer cause of the flaking paint
Blackbyrd
TN
Let me know what you find out on the charger, I need to get one for the mother in law’s car.
I apparently wasnt asking the right question. The genius 2 (2amp) often struggles with agm batteries due to the slower charge rate leading to false errors. As a result of its voltage sensitivity the 5 has similar struggles with red tops. So.... its fine for not agms but thats what's in the car I drive the least hahaha.
cccoltsicehockey
Charlotte, NC
This is interesting to hear. I wonder if it is something specific to the redtop? I have had it on an Autocraft AGM going on 3 years now on my NSX with zero issues and with construction going on it actually lives on the tender most of the last 2 years. Sadly only put 1000 miles on that thing in the last 2 years.
I guess I will need to research more as I have 2 more on standby for use in the garage once I get the last bay finished and I certainly don't want to kill my X2 Power AGMs as they cost a pretty penny.
Blackbyrd
TN
Possible its red top specific? But it noted deep cycle batteries specifically. Not everyone has the issue but its common enough I found it.
What really stinks is mine is in the trunk so I gotta pop a panel off to access it. I liked how the noco had the quick connect harness so I could leave the panel on and have the plug tucked under the carpet for easy access.
Ill keep looking into alternatives but I may he buying what swanny suggested.
cccoltsicehockey
Charlotte, NC
I had the same issue with battery tender plus models that claimed to be AGM ready. That one was a 1.25amp instead of the 2amp I am using now. Keep us updated on what you find out in your search.
Blackbyrd
TN
The noco is retired... looking at the optima 400+ (cause red and black lord its a curse)
Swapping bumpers on the trucks has really shoved me into looking for an ss bumper. Maybe IRS will be nice to me?
Nice weather and the wife has been taking the targa off the vette. Missed that feeling.
On the 71 front i wanted to get things primed, but had a busier weekend than expected so I only got a few hours this afternoon. Unfortunately most of it was squandered cleaning up the driver wheel well.
That left just enough time to strip the t top tray again (didnt get all of the gasket out and knew the patch was gonna happen) so this is prepped just need to wipe down and degrease and prime.
With a little bit of time left I set the rear 4 link cradle and torqued the hardware to spec.
Had to play with the welder a bit to get comfy with the speed last one on the right is about the best weld I can likely pull off.
I also saw a deal on the m12 detail light and snagged it
Progressing!
Blackbyrd
TN
Getting ready to prime, so I stripped the trunk jams to go along with the t top trays
And now all primed!
That leaves the upper trunk deck, door jams and inside doors panels to strip and prime.
Firewall still needs flattening and the minitub kit installed. Time to clean up the inside and get the cut lines mocked up.
Blackbyrd
TN
I bought this 4 link setup back in 2011!!! Talk about taking my sweet *** time
I finished the last of the repairs onnthe hull and got the trunk latch bracket welded back in and with everything in primer its time to finish off the rear suspension before I do mini tubs. Ive been really busy with family related issues. I took Friday off to get my feet under me and got the axle out and started welding the 4 link, its not as pretty as I hoped, but its done. Just need a little clean up then there's a plate to weld in where I goes through wall into the back seat
I have a jig for the upper control arms mounts, but it needs to be modified. It needs a third hole thats another .5 inch over. Ill break out the center punch and just drill new holes and that will center the axle under the car. Its currently setting with a .5 inch off set on the jig when its mounted under the car on the leafsprings just needs that extra .5 inch to center it. Then i can tac the brackets and ive got a neighbor that runs an offload crawler shop. Im gonna let his guys weld the brackets in.
Since last weel went from 70 to 20 degrees and snow..... baths were needed
The truck finally got the bath/attention it deserved. Still needs a decent polish but this paint is **** to put it lightly
Blackbyrd
TN
Progress! The weather has been all over the map here so I haven’t had a chance to clean any of the cars.
Yeah im getting some of that as well! Just fortunate the warm days are on the weekend!
Well there's no going back now! Tacked my upper control arms in using the jig.... that was a hole thing. Ended up having to shim the jig out a bit to get the brackets to mate to yhe axle tubes... not in the instructions BTW. Flipped it over and cut the leaf spring perches out, have to clean up the cuts a bit.
Ive got it line up to have the welds finished at a rock crawler shop once I get all the brackets tacked in.
If i had a solid afternoon I could likely get this taken care of.... time has just been limited lately.
Blackbyrd
TN
Still prepping the rear axle, I should probably focus on finishing the cradle, but I really want to cross this off the list so I can get them fully welded and the rear end powder coated.
All the bracket welds for the leaf spring are gone on the passenger side, this is not a quick task!
zmotorsports
Northern Utah
Looking good, but just a suggestion if you are going to have it powder coated, after removing the bracketry and grinding the welds down, if you run a DA over it with 60-grit sandpaper it will really smooth out the grinding marks and there will be less chance of the grinding marks showing through the powder coating.
Blackbyrd
TN
Took advantage of a long weekend to do some wife honey does.
Doing a little landscaping and have some plans. This was my son's sandbox area and weve struggled with what to do with the space since he grew out of it.
Over the course of 2 days we built 9 planter boxes, simple ones no complex cuts just measure and work the assembly line. Chop saw from last year made quick work of the cuts.
Built 4 the first day got them fully built and lined on the inside
Got them placed on the backside of my old retaining wall for the sand pit, we started cleaning it out to grass it. Deck is also in need of a wash and seal. We had a really wet summer last year and it needed it then. Still need to mesh and lone the 5 built the 2nd day. Still a work in progress it was cold and rainy Sunday so I moved to the inside.
The dish washer was in this house when we moved in 15 years ago and no telling when it was installed. the house was built in the 90'S so im guessing during the reno in 08 it saw. Its been doing subpar job the last 6 months or so. This brand new LG unit fell into my lap when a buddy moved into a new house but brought a different dishwasher. Not my best Sunday, but spent the rest of the evening at my parents for Easter dinner
Definitely not a "fun" install, but as a bonus its much quieter and works
Blackbyrd
TN
Double post separated house and car stuff
Axle housing leaf spring brackets fully removed. Thanks Mike for the DA tip, definitely smoothed it out better. I had to use the bamdfile to do most of the work.
From there I got my lower control arms mounts set, and got the inner upper control arms boxes prepped. Also got new clip and hardware for the original leaf spring front mounts as well as new mounts.
These brackets sandwich floor pan between themselves and the 4 link cradle, then they get welded in place.
Not close to getting ready to tack the lower control arms/swaybar/shock mount brackets to the axle tube!!
My tool box was a wreck after this weekend...
Blackbyrd
TN
Kiddo's 10th bday is this weekend so ive been on house detail since we will have guests.....
.managed to eek out a little bit more on this. Upper arm boxes are bolted tac'ed in. After I get the axle set ill finish all this up (bout time for minitub!!)
Started to set the lca brackets in place.
My plan, since the jig and cradle fix the upper control arms and are set to a defined length for install. I can use them to center the axle under the car and get it in the right plane. The lowers are fixed length, and the ride height is defined in the instructions from the mounting point on the cradle thats welded into the car, and the mounting point on the lca bracket. In theory at ride height and the pre defined length measurements in the instructions geometry should be set and the brackets can be tacked on where everything rests/ interfaces.
I also considered making some ride height Sims out of flat stock essentially turning the lca bracket and control arms into a nest to hold the axle housing, and still use the upper arms to center it.
Blackbyrd
TN
I wish i could say ive made more progress, but ive been on yard duty. Almost wrapped up this project now. Gotta do a little water run off management in the low area where the deck and dirt meet.
Probably gonna do a French drain since everything under the deck slopes into the cave anyway so I can catch it where it pools and redirect with a little digging. The the rest will get sewn in clover.
Got lucky with the fuel line, I got to fish the new line with fittings through my access panel without dropping the tank.
Leak is resolved but need a new bracket to secure the line and thats where I got stuck. Just not enough time in the days then I need to drain the tank and she should be back on the road.
Got stalled on the 2nd gen. Feel like I needed my 3rd member before I finalized the suspension linkages. I thought I had 35 spline axles and had a diff from speedway in the cart. Got this nagging feeling to check my splines again. Glad I did I have 33 spline axles, so that adds to the cost since that makes them a custom build through most venders since I dont want a spool.
So with some of the yard projects in motion that will have to wait. I can finish welding and cleanup and work on the minitub atleast.
Blackbyrd
TN
Been a while......
Yard project got finished mostly (rain washed all the straw and clover pretty good) but its a start.
The bird made her maiden voyage of the summer with no leaks, but some newly identified clunks. Seems i have a bit of suspension dialing in to do still.
Then reshuffled so the house sitter could use the garage. Not gonna lie ...... i enjoyed this view
Made our annual trip to St George Island with my parents in tow this year
I woke up to my father and son out on the beach, greatful for moments like this.
Made some progress on the 2nd gen, but nothing worth posting pics of, just more welding of the 4 link. Next month I should be able to get my 3rd member and that will get me on the right path again.
Been having some fun with chatgpt..... i let it evaluate my shop. Its pretty fascinating what it came up with/ noticed on my shop. I expected it to make some pretty radical change suggestions and it really just offered refinements that honestly made a lot of sense. It more or less reinforced how I have things setup, with suggestions that are more about optimizing the existing functions.
Blackbyrd
TN
Getting my feet back under after the vacation.
Been fighting a clunk in the rear suspension on the Firebird that showed up after i swapped to ridetechs coilovers. What I uncovered is a bit embarrassing, clunk was at the chassis mount side of the panhard bar. Whenever I went over one sided transition big metal clunk.
I thought it was preload/bind... turns out it was the wrong hardware. Oe hardware uses a shoulder'ed alignment bolt so one hole onnthe bracket is larger than the other. I had just a straight threaded bolt in there, so hard enough bump and it was popping. So new hardware en route.
Not got motivated enough to weld yet haha. Just general cleaning and organizing.
Finally decided it was time to work on 3d modeling, downloaded autodesk (Fusion360) watched a handful of tutorials and got into it. I want an insert for the existing bezel that I can build some guage pods onto, but it needs to fill the space first. So i modeled the passenger half using dimensions fromma 2d template i made and its currently printing. Prototype v1
Blackbyrd
TN
After falling down a rabbit hole and fiddling to 1am.....
Rev 3 fits!, not 100% aligned with the curves, but at my current skill level I call it a succes. Now to print the mirrored half and see where we fit as an assembly.
Blackbyrd
TN
Ive been fiddling with this concept for several years! Ive photochopped it, made mockups and sketches. Id kind of decided id send the cardboard template to someone with a printer along with sketches and dimensions and call it a day.
But when we decided to get my son a 3d printer for Christmas I saw an opportunity haha. I have zero experience doing this kind of work and getting something fruitful out of it. Had i guess i should say.
Even so there's tons of things you can print just accessing the app. So yeah "one of us"......
cccoltsicehockey
Charlotte, NC
That is awesome. Definitely a million uses. I keep putting it off because of the time factor and the current list of projects. I know long term I will find endless uses for one. I am sure your son really enjoys it as well and you are both getting use out of it now.
Blackbyrd
TN
He has printed endless fidgets, and tinker toys with it hahaha. Ive found a few things I "needed" while I was at it.
Version 3 dropped in so well I made a mirror to move into the next phase of refinement. This is where experience would probably make this super fast. My struggle has been editing things without moving the rest of the model at this point, but still learning
A few more tweeks and it should be solid fit.
I got my new hardware in for the panhard bar on the bird, got that swapped out and had a buddy come over to set in it so I torque it with the right preload. Im looking forward to the test drive. It had the wrong hardware at both ends, pretty aire thats why the back end felt floaty at times.
Blackbyrd
TN
I got real motivated, ive been trying to figure out a way to get it up off the floor for a while. It hit me I could use one of these slim profile tv mountd if I had a plate to go between the preasure washer and mout.
A little cardboard aided design and some scrap 14 guage later. Id had this mount for a while just hadnt been motivated to get out the hammer drill and get after it.
Test mount went well, now I think i can paint the plate and move on. Need to figure out my wiring ao thats not a mess but really happy with this 30 minute job haha
Xti04
Nice work! I need to move my cleaning supplies closer to the pressure washer area, but its also where my panel and air compressor live so theres not much space left there.
Blackbyrd
TN
Thank ya gentleman, ive found i can shorten the power cord by opening the gfi plug and disconnecting it. So thats on the agenda for later. Then ive got a foam cannon hanger and I need to hang the dog boundary fence back up, then I can clean up the mess
Blackbyrd
TN
By modern standards my welder is a dinosaur (early 2000's) and this helmet was purchased around the same time frame. I traded a nice Gibson Les Paul for this setup.
But welding under neath the car in this helmet has been beyond frustrating, its heavy small view window lead to me making poor choices and getting a gear head sunburn on more than one occasion.
So I upgraded notice the massive difference in viewing real estate! Im hoping this makes the 4 link craddle job a little better. Ive been fighting it the past month! It also has a light, but it sticks on the top so it may not fix my fitment issue of my head under the car where it needs to be, but hopefully the bigger window helps
