I don't understand it either Bob. If it re routed the I take inlet somewhere else I get that, but in this case it's all the factory location... it seals to the hood and takes advantage of some duct work at the upper grille on the bumper to get gold air from outside the car. It didn't use the grommets to hold it in place either?! Just put bolts dowles through oversized holes and has one anchor bolt at the bottom. I get mad just thinking about how poorly this was installed. It's all fixed now.... maybe I'll even get some better performance out of it haha. Or atleast more blower whine haha.Adam, I don't understand someone paying for premium aftermarket parts and somehow not installing all of them. Maybe people half-*** a mod because it's a little more work.
I shopped for a CAI for my PT Cruiser and almost all of them included some tubing and a filter but located the filter in the engine compartment right behind the radiator. The stock intake box pulled air in from the chamber in front of the fender liner so it was already pulling cold air. I ended up with a sheet metal walled replacement lid with the filter that looks a lot like your Roto-Fab setup. The stock plumbing from the turbo to the filter looked like it came out of a vacuum cleaner with its corrugated turbo outlet adapter. I had to make the turbo runner myself from bits and pieces. Because it had some holes in the side of the air box next to the fender, I removed a section of the hood weather strip. Not sure how much outside air gets thrhough there but I suspect every little bit counts on a turbo. When I was done, it sure felt peppier and sounded better as well. Bigger exhaust and a Stage 1 ECM turned the car into something that surprised a lot of kids who thought their V6 Mustang was the be-all, end-all.
I also put a Diablo Sport 93 octane tune on it. No idea what kind of horsepower the engine put out but based on the number of engine mounts it tore up and the sound of the tires when floored at 30 mph, it's better than stock. I really get a kick out of the Cruiser because it's so docile looking. At a little less than 3,200 pounds and probably in the 230hp range it's a dog compared to the 556 hp Cadillac CTS-V but my '87 Corvette weighs a little over 3,200 pounds with a 240hp engine (but 80 more ft-lbs) needed headers, roller rockers and a few other mods to be as much fun. And folks don't think of Corvettes as whimpsOh I'd imagine you terrorized the kiddos with there v6 stangs.... probably could disappoint the 4.6's oder that era as well....
Exactly! Modern day v6 cars put out old school small block v8 power these days. The sound ***** though.....I also put a Diablo Sport 93 octane tune on it. No idea what kind of horsepower the engine put out but based on the number of engine mounts it tore up and the sound of the tires when floored at 30 mph, it's better than stock. I really get a kick out of the Cruiser because it's so docile looking. At a little less than 3,200 pounds and probably in the 230hp range it's a dog compared to the 556 hp Cadillac CTS-V but my '87 Corvette weighs a little over 3,200 pounds with a 240hp engine (but 80 more ft-lbs) needed headers, roller rockers and a few other mods to be as much fun. And folks don't think of Corvettes as whimps
Adam, I hope you don't mind but I'm copying your post to my "Luckiest Day of My Life" thread. It's so easy to focus on the things we don't have rather than find joy in the things we do.Now I'm setting with 2 of my dream cars and building my 3rd in a functional shop that puts a big dumb grin on my face. Coming to the realization I chased the dream for so long I kind of missed I was living it......
I don't mind a bit! I didn't realize when I posted that it would resonante with folks. Just another reason I enjoy this forum so much. So many like minded people.Adam, I hope you don't mind but I'm copying your post to my "Luckiest Day of My Life" thread. It's so easy to focus on the things we don't have rather than find joy in the things we do.
What does a ABS delete kit consist of? Is it basically taking out the ABS module and just having brake lines run from the new master cylinder that is non-ABS model to the wheel calipers? What about the computer and the annoying ABS light?Doing an abs delete on my firebird has been on my list for a long time. Ever since I swapped to a 9 inch rear abs hasnt worked since that deleted the rear speed sensor. So in comes this kit and new brake lines to boot.
Everything from the master cylinder all the way to the calipers is gone (well will be) so that will clean up the driver side a lot as well.
While I'm under neath I'll figure out where my fuel leak is and clean up the underside a bit.
I'm not sure I've mentioned how much of a Frankenstein this car is?What does a ABS delete kit consist of? Is it basically taking out the ABS module and just having brake lines run from the new master cylinder that is non-ABS model to the wheel calipers? What about the computer and the annoying ABS light?
Sounds like a project for a rainy week when you're really really bored!...but it's not like it's in the way and its mostly hidden at this point so is it worth the effort?
That's right I did a bunch of research on HPtuners last year. I think if I remember correctly I have to buy 2 credits for my Camaro. It also would allow me to dial down the torque management as that is no longer an issue with the fully built 4L65E I have now. I hoping I can get some of those chirps during the 1-2 gear change under throttle.@bj383ss
Well part of that stand alone harness ment figuring out guages... it was gonna take some effort to make the stock cluster work. Going full custom was actually easier believe it or not.
Yeah HPtuners allows you to setup the ecm to ignore specific fault codes. I have plans to redo the cluster and I'm probably gonna put that off a little longer. Guage setups have become costly more expensive since I dis this setup....
Yes! Trq management pulls timing to soften shifts even at wot!!! Terrible for performance!That's right I did a bunch of research on HPtuners last year. I think if I remember correctly I have to buy 2 credits for my Camaro. It also would allow me to dial down the torque management as that is no longer an issue with the fully built 4L65E I have now. I hoping I can get some of those chirps during the 1-2 gear change under throttle.
My dad's 64 El Camino had a 283/PG.(When I was a kid) When he finally had to get a new trans he put in a TH350 with a street/strip shift kit and it would chirp the skinny tires every time you got on it from 1st to 2nd gear. I loved it.
Bret
But keeps a stock 4L60E from gaining 5 extra neutralsYes! Trq management pulls timing to soften shifts even at wot!!! Terrible for performance!
No that is inevitable..... nothing keeps the 4l60e from 5 neutrals hahahaBut keeps a stock 4L60E from gaining 5 extra neutrals![]()
Adam, I feel your pain and in my world, abs is not my friend.Doing an abs delete on my firebird has been on my list for a long time.
Adam, I thought they were expensive way back when. I decided the stock gauges on the '72 Corvette worked well enough and looked into having them refurbished or replaced with aftermarket. Decided against a second mortgages and re-faced the gauges in white with a kit from WhiteGauges.net. It was better than me trying to touch up the original gauges.Guage setups have become vastly more expensive since I dis this setup.
Bret, when I was consulting for AOL I blew the sprag clutch on the company car, my '87 Corvette (hey, the IRS doesn't specify what qualifies, just that it's used primarily by the business). I was too busy with the paying job to rebuild the 700R4 so I paid someone to overbuild it and install a modified valve body. It was actually a better deduction than fuel and oil changes. A full-throttle 1-2 shift breaks the tires loose and shift the car sideways just enough to scare the **** out of anyone not expecting it. The two 255/50 16 radials makes quite a chirp.My dad's 64 El Camino had a 283/PG.(When I was a kid) When he finally had to get a new trans he put in a TH350 with a street/strip shift kit and it would chirp the skinny tires every time you got on it from 1st to 2nd gear. I loved it.
Dakota Digital is nice and they have the gauge holder made for the 71 Camaro dash so you can use the original gauge cluster bezel. Hardest part was wiring the module in the dash area as it was getting tight with AC ducts in the way. They have a set that looks like the factory style with the orange needles, but they were up in price, I think $1,500 or so. I opted for the VHX as it met all of my needs. If you decide to stick with original gauges, I got a set on the shelf I can send you for extras as you work on getting a good set. I can't guarantee they work though as I pulled them out of a 77 Camaro, I think it was, that was just a parts car.@Bob Heine I've worked on a c4 vette a few times, but didn't know that's where the abs was!
I was helping a buddy move one to a storage unit and the battery was toast and the car died on the way...... it was 8 degrees out that night. I had to help him swap out the battery in a parking lot. We had to take turns setting in my truck keeping out hands warm!
Yeah I want to redo the guages for something less retro in the 01. I've priced a set from speed hut several times but it's gonna be 700 bucks or so so I keep putting it off. I'll have to do a lot more to make a new cluster work.
I havnt even thought about what I'll do with the 71.....
