Blackhawk SJ-2 replacement floor jack wheel
goody4her
I need a replacement floor jack wheel. My floor jack is one ton and a half capacity.
I have a 1.5 (one and a half) ton floor garage jack from Sears. I busted the rear wheel on it (the smaller ones) since I dropped it and I need to buy a wheel for it, I really should get two (if I get new ones).
The sears MODEL number is #727-12102 (or Blackhawk SJ-2). It is an older model made in the 70's, Sears no longer has the wheel listed. I went to the store to see if the clerk can match it up with the newer jacks and I also went thru sears parts direct. No luck.
Does anyone have one floor jack wheel for sale, I do not know if they are steel or cast iron, I think its cast iron.
The wheel does not have bearings, it just a hole in which you slide a bolt in there. Floor jack has 4 wheels, two large ones in front and two small ones in back.
The busted one is for the back.
I did not take a picture of the actual garage jack since that would not help in anyway.
My jack works great and I would hate to toss it for such a small issue. The jack is very heavy so I am not seeking repair. It would cost a fortune to ship it. Thing weighs like 100 pounds.
I did google this wheel and two companies responded, but the price was way to high. The replacement part number is A673154 (wheel and caster unit).
Please let me know if you can help, thanks. I am sure someone out there might have one used floor jack wheel.
PS. The wheel is like 6 CM tall (2 7/16"), almost 2.5 cm (1") wide and the hole in which the bolt goes in is like 1cm (7/16). (sorry I never learned fractions that well). Bore is 13/16
