Blast room ideas?
ripper70
Oregon Coast
Has anyone built a Sandblasting room?. Ive been looking at the Norton blast rooms to put in 1 of my bays but might be cheaper to build my own.
rustyjames
central nj
If I were to do it, that's exactly what I would use, shipping container, that has to be the easiest, quickest and cheapest way.
isb cornbinder
One of the guys here in Canada bought one of those rag and tube car-port shelters and has it set up in his yard for abrasive blasting. He lays a tarp on the ground so clean-up is little more than picking up the corners and gathering the sand and other material into the middle of the tarp.
keen
geneva, fl
buddy of mine is a pro blaster - and he did exactly that for years. Upgraded to a cheap carport eventually before moving up to a concrete block room...
James-W
Southeastern Wisconsin
I have heard of people making one out of wood and then for a floor they have expanded metal so the abrasive media can fall down and get used over again. If you only need it for occasional use I think that would be a fairly inexpensive way to do it. If you will be using it all the time then I would go with concrete block.
rharman
SoCal
Check Don Long's posts. He built one out of a container. "The big party garage".
