rwa2004
Hi - I am on track to build a 28x44 shop that will be used as a machine and fab shop.
I'm having trouble deciding between a block foundation on a footer with slab poured inside or a pole barn and slab. The main reason I want a block foundation is so that I can have 2 courses of block above the floor so that the stick frame wood and outside metal siding is up off the ground. The main reason I want poles/slab is because I want low cost.
What do you think?
Location is Western PA, where the frost line is 3' down and the ground is always wet. The property/area is pretty flat which means no retaining walls but also poor drainage. Shop will be heated, but not through the floor. I planned on insulating the floor vertical on the perimeter and under the slab on the outside 3-4 feet.
I do have a Cincinnati mill and plan on a few lathes and mills, so slab stability is important to me. I do understand that regardless of poles or block that the slab will float separate from the walls. I fear that a slab inside of poles will not be well protected.
What do you think?
