oifla
Hello all,
Posting to see if anybody has any ideas on how I could best modify my place to better meet my garage/workshop needs. Pls read below and let me know if you have any thoughts/ideas - thanks!
The short version is that our house came with a 'mother in law' apartment/little house next to the main house which is really a garage that was closed in to serve that purpose. With some work, it could (relatively easily) go back to being a garage.
Here's a shot of the front (taken from the road)
and a close-up of the building (note the elevation change)
Here's a very rough plan view sketch
and a bird's eye pic
Issues I'm working with:
Size:
- As it currently stands, the building is about 450 sq feet but it is not currently have a garage door sized access. In order to do what I need as far as workshop space, I need about 900 sq ft (if not 1,000).
In order to make up the missing square feet, I could add more square footage behind the existing building (it would be on two levels b/c of the elevation change but still workable), see pic here.
I'm not great at laying blocks but I would be ok if I ended up with a mixed block/stick built building.
Adding another slab behind the existing block building is easy enough, how to fix the roof is another matter.
I'm considering (a) treating it as an addition and simply adding onto the existing or (b) eliminating the existing and doing a new flat roof on the new and existing structure to tie things together.
Access:
The large maple out front would have to be taken down before we could drive up to the use the front for garage access. Alternatively, if I left the tree in place, I could use the 15 feet I have to the property line and try accessing the garage either from the side or, putting in more gravel, I would reverse into the garage from the back yard (nearly missing the septic system).
- Another alternative is to tear down the existing block building and put up a new stick frame using the existing slab (and a new slab next to it).
Whatever way we end up going on this, I'd likely end up doing the bulk of the work myself (except the cement work). Doing the work is not a problem but I did want to throw this up on here to see if anyone had any other ideas. A new set of eyes (or two) on this would be appreciated. Thanks!
Size:
Access:
