"blocking" for lights in garage with metal ceiling
jeepnatv4life
Harrisonburg Area VA
What is the best way to "block' for a light prior to mount my metal ceiling?
Just toe nail a 2x4 where I want the fixture to go? and run the wire to it is what Im imaging Just want the best way to do it.
matt_i
SE Michigan
Assuming you are using the typical "round box" for ceiling, that's a good idea. There are plastic round boxes already equipped with metal "sliders" which expand to fit the gap between joists/trusses, you just open it until it contacts, then nail in place. My personal opinion is the wood blocking is stronger and nicer.
Highbeam
Mt Rainier foothills, WA
Are you going to surface mount a metal box for the fixture, just run wire through a small hole in the ceiling to lead into a tube fixture, or try and recess mount a box above the ceiling?
I mounted my fluorescent tube fixtures to the ceiling with no actual box, just staple the wire to the joist, drill a hole in the metal ceiling near it, grommet the hole, mount fixture.
I used a 2x6 block layed flat and toe nailed in to the joists above the metal to surface mount metal boxes which I then mounted my smoke alarms.
The only time I used a traditional ceiling light box was for my ceiling fan. That ceiling fan box, like a ceiling light box, mounts to the joists and you cut a hole in the metal for the box to slightly protrude into the space. No support is needed other than the joists.
Here's a picture of all three.
Trihle98
Athens,AL
I made a cardboard template for the back side of the light fixture and drilled holes for mounting locations. I then used that template to mark and drill holes in the metal ceiling panels and used toggle bolts. It was a breeze and it allowed me to wire the fixtures with zero help from anyone. Good help is hard to find these days I tell ya.
