Hi Guys,
I have a cottage that is on a crawlspace and is a single floor (around 900 sq. ft.). I would like to blow out the plumbing in the cottage when we shut the place down for the winter. I’d like to install an air fitting somehow so that I can use an air compressor to blow out the water in the system.
We are on a well. The well goes into a holding/pressure tank and from there into the rest of the house plumbing (hot water tank, faucets, shower etc.).
Where in the plumbing should I put the fitting to hook the air compressor to when I want to do this?
What type of fitting should I use and how much air pressure do I need so I can size the air compressor properly? I would imagine a small one would most likely do the job but I’m not sure.
I was thinking the procedure to do this would be as follows:
- Shut off well pump
- Open faucets to let water out and de-pressurize the system/holding tank
- Hook up air line/compressor and blow out remaining water in system
Sound about right?
Thanks.
Sound about right?
Thanks.
