Blown in insulation and Attic Storage.
Jakethegriff
Outpost 31 (MN)
Good morning Gents,
I'm in the process of wiring, insulating, followed by sheetrocking my garage. I was just thinking of the pros and cons of Batt vs blown in, and I was hoping I could still utilize some garage attic space for storage. I/E Christmas lights, 1x lumber, etc.
My garage is 920 sqft (40x23) three stall, rectangular. 9 ft inside ceiling (after finish)
I live in Minnesota, so the winters here are brisk. I would like to blow in insulation in the garage for sake of ease, cost and r-value, but I also would still like to retain some space for storage,
would it be feasible to create around an 18- 24" high plywood barrier, against a trusses, to hold the blown in insulation, say on 3/4 of the garage (left side of pic, away from house), while using batt style on the remaining 25% (over right side, the stall closest to house)?
I would most likely place a couple of 2x4's spanning the joists , to accommodate said small storage pieces or totes of Christmas decorations, small lumber etc.. nothing crazy/or heavy as the truss are 2x4 construction.
Would this be worth my time for retaining some storage space?
kd3pc
Northern Neck
As your trusses are only 2x4 then you would be limited to 4" of batts or blown in, if you want to keep the storage floor..minimal R value......but I have blown in R-45 in my garage, in Middle Tn....and that is 18-20" if I recall.
You will have to decide which is a higher priority - insulation...or storage.
kTHREE
MN
I was in the same position with my garage. I've only recently decided against it. While it's nice to have storage above the garage, it's a pain in the *** to move anything and always requires 2 people. Although my ceilings are 10'+.
Went with an outdoor shed instead and will do blown in insulation this fall of about 24" and forget about it.
prostreetamx
Las Vegas
We like to use 10" of blown in insulation here. I wanted to be able to have access in my garage attic for future changes but did not want to disturb the insulation by stepping on the trusses buried in insulation. I solved this by installing a platform the entire length of the garage by using 2x6's on their side and truss clips to hold them. I put 2 layers of 1/2" plywood on top to support my weight and put fiberglass batts below the platform before closing it up so when I blow the rest I don't have to do under the platform. I have a vertical chase at each end that connects to a soffit I ran around the walls at 8" so I can add stuff later without cutting holes in the walls or ceiling. It get pretty hot here in Las Vegas and I don't plan to store stuff in this attic but it would be pretty easy to add some shelves above the insulation if I wanted.
seanc_mt
Storage is cheap to build. Heating and cooling are expensive when insulation is not done right.
Dragfluid
Pillager, MN
Blow in 19" of cellulose and store the junk elsewhere.
I'd like to have a buck for everyone that had to have stuff stored topside, only to still have it up there 10 years later without ever looking at it.
J
Jakethegriff
Outpost 31 (MN)
Yeah, after looking into it more, I don't think I should be putting anything upthere to begin with. I was leaning on full blown insulation (pun intended) but was just looking for a second opinion. I have extra Aluminum siding, 1x6-8 lumber and a few of my sons metal tonkas up there - but I wouldn't be heartbroken if they went away, or just relocated. Thanks guys.
