Board and Batten Siding Where to set the Bottom
tstaude
SE Wisconsin
On the barn project I bought 1x12 rough sawn pine which will be installed as board and batten. The building is post frame but still has OSB on the outside.
I am wondering if I should just run the battens down past the level of the OSB or have something below with some flashing or maybe a Z channel at the bottom.
I have a picture of the two options below, represents the bottom 4 feet of the wall, not to scale
lilredex
Toronto
We thought about B+B but went with channel siding instead, for a smoother look. More work but worth it in my opinion. Installed the "Z" flashing, because the foundation was there. That was about twenty years ago.
billconner
Thousand Islands NYS
I think either will work if you keep the b&b 8 to 12" above the ground. I slightly prefer the one without the flashing.
If however you are close to ground, A pressure treated (for ground contact!) skirt board and flashing would be my choice.
nadogail
Coronado, CA
Amen
T
tstaude
SE Wisconsin
It will be about 6" from the dirt/grass.
I would like to run it without the skirt board, but may end up going that route so I have something to set each board on and make sure it's all straight. Still undecided
Zeke
There are many ways to keep the boards straight at the bottom. If you choose the Z-bar you don't want to rest the bottom of the boards on it, you should keep a 3/16 to 1/4" gap To allow for moisture to not be trapped and/or wicked up into the siding.
Not using the Z-bar solves that problem. But IDK, I like both.
T
tstaude
SE Wisconsin
gotcha, so if I do use a Z-bar then definitely use a shim to keep the gap.
So you think the option on the left looks good?
KenC
oklahoma
I like the LH version. With a couple of caveats. 1..bevel the bottoms of the 1x12 outside longer to help water drip off, not stick to the bottom edge and soak in. 2..Paint/seal/treat that edge before installation to repel water. Boards rot most quickly at end grain as it is like a sponge.
#2 applies no matter what the final choice may be.
I would also want a rain screen between the pine and house wrap. That allows the pine to dry from the back rather that trapping any seepage between the board and wrap.
billconner
The rain screen is a good design - horizontal furring strips to space the boards out from the OSB. I support the beveled bottom edges. If you could, soak the ends for at least a few minutes of each board in whatever preservative coating you'll apply.
PoorUB
Fargo, ND
Six inches from the ground and the lower part of the siding will never dry out. I would put in a skirt board, PVC prefered, or treated, the Z flashing and leave a gap from the bottom of the siding to the flashing. Better yet if the flashing does not have 90 degree bends, but a 45 degree angle so water runs off.
Kaizen
New England
you definitley want a rain screen for an air gap. The build show just did something simliar and talked a lot about the why.
i'd prime both sides before install. The rain screen will help so both sides dry at the same rate. Agree pvc up to a foot. I used pvc and then a piece that is pvc and kind of like an L with a drip edge. Acts like flashing.
rayra
Escaped from Los Angeles
seconding the bottom support and Z flashing. Particularly in parts of the country where that weird white stuff piles up against structures for weeks at a time.
T
tstaude
SE Wisconsin
So is rain screen literally the furring strips?
K'ledgeBldr
Johns Creek, GA
If that's the case- the grade is wrong! Fix the grade- don't Band-aid with different material- it to will eventually rot.
billconner
Yes. With clapboards, vertical. With b&b horizontal. Screening (ss) or other material (that 3m scotch pad like stuff) at bottom to prevent insects, though maybe the horizontal furring will do it. Honestly have not done it with b&b.
KenC
oklahoma
Using horizontal battens for rain screen behind B&B is not best practice. The horizontal boards block drainage. Better to use one of the sheet materials available, like this:
mejhaha
Also second the rainscreen with battens running vertical - battens normally can be any material, do not have to be pressure treated.
Cor-A-Vent makes a great product for the bottom of the rainscreen; to let air and water move but keeps everything else out. Is reasonably priced and easy to work with. Normally the top of the rainscreen vents to the soffit space.
billconner
Would be a lot of vertical battens for board and batten siding, and might need additional blocking since the spacing is unlikely to align with studs. I like the rain screen but may not be a good match for real board and batten siding.
billconner
If you did do horizontal rainscreen battens, could just use a wide one - PVC or pressure treated - at bottom. I might consider no rain screen and install a 12" or wider strip of coil stock between OSB and boards, to get them as far as possible above ground and avoid the Z flashing.
