body clip pliers
uscarry45
You may notice my ignorance in this post as I don't know what they are called. I am looking for a set of pliers that will remove the plastic automotive body clips.
I am most interested in being able to remove the "push pin" style that I think needs a special set of pliers to be removed so they can be reused or at least removed easily.
I see blue point make some, cal-van, and gear-wrench does anyone have any thoughts or recommendations on what to get?
Thanks
LB-1911
Northwestern Il.
You may want to give this set a look.
2 PIECE KIT WITH MULTI-COMPARTMENT ORGANIZER CASE
https://www.harryepstein.com/index.php/automotive-tools-plastic-body-clip-rivet-removal.html
I got the body clip set as well from sk... I hope it is nice.
Are you talking about the kit with the adjustable head trim clip pry bar? I got it when it first came out a couple of years ago. it's pretty sweet for wheel well splashshield fasteners. I also like the SK push thru trim tool. it looks like a green screwdriver handle with a pin on one end and a small pry bar on the other end. great for those push pin type fasteners found on so many late model Asian cars.:thumbup:
ocloc24
Harbor freight has them as well. They're incredibly basic and I see zero difference between theirs and even snap ons. They look identical, I wouldn't doubt if they're made in the same factory.
APS2000
All good choices above.
Don't forget the HF coupon.
https://m.harborfreight.com/push-pin-pliers-67400.html
https://m.harborfreight.com/panel-clip-pliers-67399.html
