American Locomotive
Working on a Toyota restoration project. We first laid down epoxy, put in some body filler to fix little spots, and then coated it with 2K high build primer. Well things got in the way and the project has been sitting for many months, probably like 7-8 months. I am aware I will have to scuff and clean the 2K primer really well before coating it with more epoxy because of the sitting time.
But that's not the main issue. The problem is on one of the fenders, I noticed that we didn't blend a small spot of body filler very well, and it's definitely pretty noticeable. I don't think the 2K primer applied heavy enough to block it out either. I think it's going to need a very thin coat of filler in this area to clean it up. However, a few sources I'm reading online are saying that 2K takes a very long time to fully cure, and it's not a good idea to put filler over 2K.
Do you think given the very long time my panels have been sitting, that the 2K should be sufficiently cured that a quarter-sized bit of body filler should be okay to apply if I scuff up the 2K? I'd hate to take this panel back down to metal (like literally, I will hate the panel).
