j789139
Hello all,
The ole’ 96 civic ex is showing her age with body paint rust, the worst of which is above rear d/s tire. Is this worth trying to repair, or would you replace entire panel? If worth trying to repair, what would you use to remove the bubbling paint & rust?
What would you use to scrape the rust off? FWIW, I've got this ^^^ Polycarbide Abrasive Wheel. Also have rust remover called "Naval Jelly", which I was thinking I could use as alternative to your Rustbullet or POR, suggestions. I'm OK, at diy, better with proper direction, from more experienced folks, but this is my first venture down this road, so have to take it a step at time.
