Boice Crane drill press
olddog1
I'm about to start the resurrection of this neglected '40s-vintage Boice Crane Model 1610 drill press. I imagine nearly everyone has a couple of the pulley guards lying about, but I don't seem to have one! Super-long shot, I know, but if someone does happen to have one and has no need for it, I'd be interested. In the meantime I'll fabricate some sort of a guard to keep my scalp from fouling the belt.
Does anyone know the purpose of the two pulleys on the side of the head?
FrankLee
seMI, 48317
My swag it was custom made for quill return. A weight would hang from the rear pulley. When feeding the quill, a cable would wind around the front pulley.
Is the original spring there and working?
O
olddog1
That makes sense. The original spring is there and works fine, so I'll leave it as-is. Thanks for the information.
Mintgrun
Kingston, Wa.
I'd guess the side pulleys are for a cable actuated foot feed pedal. A lug fit into the notch on the front pully, with the cable running around to the back pulley and down to a hinged pedal. I tried searching for an example online and failed.
O
olddog1
I know what you're talking about. That makes more sense than a return, since the return spring is still in it and works fine. Also, the original lever has been replaced with some sort of bent rod, making me think someone removed it 'way-back-when for the foot-feed you mentioned. Maybe I'll hook it up!
O
olddog1
Well, here it is after some extensive cleaning, stripping and re-painting. The motor runs like a watch and after lubing it and attaching a new cord, I'm sure it'll live longer than I will.
I replaced the two spindle bearings since one was squalling like a mashed cat and I'm sure the other couldn't be too far behind. The deep bearing on the head pulley was smooth and quiet and removing it looked like it could come out worse than leaving it, so I cleaned it, lubed it and left it.
The quill clamp screw had been replaced with a common AN bolt and nut so I made one to look similar to the other original clamp bolts, which are knurled and bent. The only 5/8" material I had was a super-long, rusty 5/8" bolt from the scrap pile, so I cut the end off that, turned it, threaded it, knurled it and bent it. Afterward, I zinc-plated all of the clamp screws, the spring housing, the housing cover and the quill stop. Then I treated them with sodium disulfate/yellow chromate.
The brass quill stop nuts were worn pretty smooth so I straight-knurled them as they were originally.
The last thing to do was to make up a simple guard to replace the one missing for the head pulley. This one is made from scrap 2024T3 aluminum.
This little feller had led a dog's life and had been neglected for many years, but I think it cleaned up pretty nice and will be a nice drill press. Gotta love these old machines!
Brett Call
Are you still looking for parts I have one the motor is shot but alot of the rest is good 1000002812.jpg
