caper150
After years of having a too small heat source for my in-floor heat I purchased a boiler to provide the proper heat for the system, even hired a heating and cooling company to do the install.Anyway heres my issue. I haven't been down to the shop for about a week as I was deep into a ceramic tile insatall in the master bath. I went down tonight and the air temp inside was only 40*.
I checked the boler and it was working and I checked the air bleeder screw and a lot of air came out.So I'm thinking theres an air lock so I shut the valve off for the loop and force the water to have to go out to the floor. I can hear it running and there is heat on the pipes going out to the floor now. The pipe going into the boiler wasn't as warm as I thought it should be but after awhile it warmed up. I did find a little puddle next to the boiler, but I'm not sure where it's coming from, when Iopened the air breather some of the water came out once the air stopped coming out.
is the boiler done for if there is a leak in it? I plan on calling the guys out to look at it again they've been very good to me and will come if I need them.(they stand by their work) I'm just looking for some type of answer if it was an air lock and how it happened.
Here are some pics of the system:
The boiler is over size for the system and runs a constant loop and will only go to the floor when it's called for. The valve on the wall is normally horzontal and the pump on the wall is for the loop. I have the valve closed in this pic to force it out to the floor.
In this pic, this is how it normally operates
This is the small puddle I find on the floor.
This is the pump and thermostat control for the floor.
Anyone have any ideas what I can look for till they show up to look at it or I can make suggestions to them of the probem.
