[email protected]
- Joined
- Aug 13, 2008
- Messages
- 5
looking for any info on easy out always snaping off bolts
what about those seen on tv grab it
thanks
thanks
"Easy Out" is an oxymoron -- they are rarely easy. Do a search, there are many good threads on screw and bolt extraction.
It was anything but easy to remove 2 easy outs from intake manifold to cylinder head bolts. I think welding a nut on the broken bolt is always a sure way to remove it.
Any chance this was a Jeep Wrangler?
Also, that only works if there is some bolt left exposed. I always seem to break them flush with the surface or inside the bolt hole.
Tim
Corvette.Made a simple intake gasket swap a nightmare.
You'll have to center punch the broken bolt. Then start drilling it with the smallest bit and work up to the biggest. If you start going off center you'll be SOL.... Use a good quality extractor and you'll be fine.
Very strange those bolts broke. Unless they were cross threaded when installed.
Steel bolts in aluminum heads - it'll happen. I helicoiled EVERY intake/head bolt hole after that experience.
And back on topic, I agree with the center punch technique. Invest in some good cobalt drill bits and tapping/cutting fluid. Also, as aforementioned, soak any potential headaches in your choice of penetrant.
Maybe I should knock on wood here, but I have had great success with ez-outs. The way I use them is as follows. Whenever possible I bring the item with the broken bolt to my drill press and utilize that. I will start with a small hole in the middle of the broken bolt and work my way up to as large a hole as possible. I then SOAK the broken bolt with PB Blaster. I then use the largest ez-out possible to minimize the chance of breaking that too. By drilling out the broken bolt almost entirely, all that is really left is the threads so the likelyhood of breaking the ez-out is very small. It is time consuming, but it beats torching the things out, redrilling and tapping for the next size up.
Tim
Also, before center punching, if you can, hit the top of the broken bolt with a die grinder or Dremel and a small stone to square it up and put a slight dish in it. IMO, the toughest part of the whole process is getting the hole drilled center and square. This is made even tougher due the fact that bolts rarely break off square and clean (for me anyway).
Never had much luck with easy-outs. Never had one break on me, but I can never seem to get them to bite - they just end up reaming the drilled hole.
Always had much better luck with these, found at Autozone of all places.
